Storm blew out power, when the lights came back on my TV had no sound, checked everything,
SOURCE: Post Storm Problem
Hope is last to dye. Be calm and contact the technician with best references or Authorized Sony Service. If you need more info please advice
SOURCE: power went out during electrical storm. tv never
it is problem power supply some of components are demage such as capacitor or diod is bad. You go to a service centre and repear it by a good technician
SOURCE: Absolutely no power on my Toshiba flatscreen lcd
If the HDMI cable was the only connection, then the high voltage pulse would have had to go through one or more of the video wires in the cable, through the video board, and back out the HDMI cable shielding. What troubles me is you should see the unit come up to standby and refuse to power on. That suggests there was something else connected besides the HDMI cable or the base made a decent ground. At least the panel is worth $150 or so (it is highly unlikely it was damaged).
SOURCE: we had a storm last
Did the fuse blow? And when you put in the new fuse, did it blow right away.
For five year old TV, the common failure will be the power supply module and the processor on the main board since it will be running 24/7 even when the TV is off, this make it subject to all kind of surges and spikes (I kill the power my TV's when not in use using my power conditioner power switch).
The main board can be damaged also.
Repair shop will more likely to charge you $50 to give you the estimate, typical repair will be $150 and up plus parts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
SOURCE: we had a thunder storm and the tv suddenly went
If there's no LED light at the front panel, this is an indication that the power supply board is not working/dead (I'm assuming here that you had already tried to plug it to other working outlet). First part to check in this kind of symptoms is the internal fuse of the power supply board. It is where the power cord's directly connected. If your unit is not under warranty period (if so, avail it because the manufacturer will fix it for free) open the back cover, check the continuity of the fuse using the multimeter. If you found it open replace it with same current(ampere) ratings and then try to power on the TV. If the new fuse blew again, this is an indication of more serious problem on the power supply board.
Let me know the status of the fuse and the exact brand and model no. of your TV to assist you further.
Jdvillanueva
