Aux mode don't comes out when you press function key
  • Audio Player... Master
  • 594 Answers
Hello Joseph, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Joseph, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Posted on May 23, 2019
4 Suggested Answers
SOURCE:
thesoundman
  • 41 Answers
SOURCE: can't locate aux function
Try turning the unit off first - Pioneer manuals are notorious for mentioning this at the beginning of the section, which doesn't really help if you skip to the part that you are interested in.
Posted on Sep 21, 2007
SOURCE: AUX mode
pusht the ANT button
Posted on Jan 13, 2008
dj x
  • 61 Answers
SOURCE: put in new car battery, now can't get aux to work
Hi there
hold down the source button to turn off the unit (unit must be off)
now hold down the function button till it beeps once it has done this press the function button i think 3 or 4 times and you will get a message on your deck unit saying (aux - on,off) turn on and press the source button to turn the unit back on to the CD or radio now press source button2 or 3 times till Aux shows up (press means push it let it go) (hold means don't take your finger off button)
hope this solves your problem
Posted on Mar 05, 2009
Need code for dish network 722 remote
The codes we have listed are as follows: 788, 790, 642, 796, 801, 846, 785, 660, 662, 678, 791, 792, 642, 671
If this doesn't resolve the issue for you then we will need you to try a Power Scan method the instructions are as follows:
Power Scan AUX Mode:
1.) With the desired equipment on, press and hold the AUX button until all mode button backlights illuminate (about 3 seconds), then release.
2.) Press 222 then # Hold the "Aux" button until all mode button backlights illuminate (about 3 seconds), then release.
3.) press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
Press and release the large red Power button.
4.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
To verify the code works try several different functions for that equipment.
When programmed in AUX mode you will need to press the AUX button to use the remote for your amplifier. I hope this helps!
Daniel Busa
DISH Network
Customer Service
Jun 05, 2011 | Onkyo TX-SR608 Receiver
I need the code for apex dt250a converter box
Try 10748 for your apex digital unit. If this doesn't work, you will have to go through the SetNStep procedure below.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Let me know if this works. Thanks.
Mar 05, 2011 | Directv RC-64 Remote Control
I have a Pioneer DEH-P5200 and i plugged the aux chords in the back to my ipod but dont know how to switch to the aux mode on radio...
OK - had the same problem and got it finally figured out. Power the unit on the ignition key. Press and hold the source button so the unit shuts off. With the unit shut off press and hold the function button (the key is to hold the function button down) The clock, aux etc will show on the screen. Press (but do not hold) the function button and it will move to each function. When you get to the AUX press the ^ button and the will switch the AUX to "on". Once you know, like everything else, it's pretty easy.
Nov 29, 2010 | Pioneer DEH-P5200 CD Player
How to set-up a tv
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
for Televisions
May 20, 2010 | Directv RC23 Remote Control
Just got direcrt tv and there isnt any codes for ilive sound bars wnat to do
Try this
    1. for Televisions
Good Luck:)
Dec 20, 2009 | Televison & Video
I can't figure out how to put my pioneer deh 10 in auxiliary mode. I bought one of those audio cables to plug in the red and white jacks in the back, and connect my mp3 player, and I can't figure out how...
Sorry, but I don't think you can use the rca's for an aux-in. I bought a deh-10 new and there is nothing in the owners manual that even mentions useing the rca's for an aux-in.
Used it long enough to opperate it in the dark and nothing in the setup menues for changing those rca's from outs to ins.
Feb 19, 2009 | Pioneer DEH-1000 CD Changer
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Aug 22, 2008 | Pioneer DEH-30MP CD Player
Cannot get Aux to display after new battery installed in vehicle
This is easy, Press in and hold the function button and the volume dial,.. after the function menu comes up press function again to get to Aux off.. press up to get it to Aux 1 and then press in the volume dial again and youre set!
Jun 23, 2008 | Pioneer Premier DEH-P480MP CD Player
Remote code
Use the search function, but don't give up. It takes about 20 minutes to find the correct code.
Here are the instructions
    1. for Televisions
Sep 12, 2007 | Televison & Video
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
23 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
