Question about Electric Toys
I have a traxxas 3.3 and when I press the electric start button the light pops on but right when I plug it in it shuts off everything is hooked up right no loose wires
SOURCE:
eagle338
  • 4889 Answers
SOURCE: dishwasher won't run
It is the touchpad that is faulty.. coz if the control board is faulty the unit may not respond to any button at all.. So just get a new touch pad.. If you want to buy it online.. then let me knnow i will get you the link..
Posted on Mar 13, 2008
myob247
  • 1342 Answers
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
Possible causes for your issue include:
Blown fuse
Timer or motor inoperative
Housing wiring not properly connected to dryer
Bad door switch
Faulty "Push to Start" switch
It would probably be best to have a professional pinpoint the exact defect.
Click Here for a very good source of information on Maytag dryers
Posted on Jul 17, 2008
co7196
  • 3433 Answers
SOURCE: Electric start not working
The starter relay may have a loose wire or aone of the battery cables is poorly connected. To find the relay, follow the positive battery cable. Ck the negative cable connection on the frame.The small wire on the r4elay is the wire coming from the start button. There must be current there when you press the button. Good Luck, Ned
Posted on Jan 26, 2010
  • 351 Answers
SOURCE: kenmore electric dryer, model number 86873100,
Here is a sketch for both hook ups on the dryer ..
Posted on May 15, 2010
archaeology
  • 662 Answers
SOURCE: I have a 1993 chev
This diagram is for 1998-1995 Chevy 6 cylinder 4.3L engines.
Your got the firing order exactly correct, at 1-6-5-4-3-2, but here's the thing to double-check:
The distributor rotation is clockwise (note badly rendered arrow in picture).
Since you probably got everything right, then you're left with really unusual/rare causes of
failure of the ignition system:
(a) rotor button misaligned/failing to make contact?
(b) rotor button not pressed onto distributor shaft far enough therefore failing to provide correct
proximity to distributor cap contacts when coil fires
(c) coil wire or contact loose/disconnected - press coil wire firmly down into distributor cap.
(d) distributor shaft of other damage caused during installation of rotor.
(e) spark plug wires defective from factory
(f) spark plugs defective from factory
(g) battery low - may need a charge to start
(h) ICM (ignition control module) failure - hook up your HEI (high energy ignition) tester, and
watch the quality of the spark on each cylinder.
(i) fuel problem? If spark is being properly delivered, its gotta be a fuel problem...
(j) distributor cap not screwed down flush to top of distributor? maybe just on one side?
Inspect the inside of the distributor cap - if there are lots of little metal bits all over the inside
of the distributor cap, then you know you have a misalignment of some type in there, and the
rotor and cap are destroying each other. normal operation will throw a quota of spark-ed off
metal bits inside the distributor cap, but since your cap is brand new, your attempts to start
the engine should have rotated the distributor so few times, you should see no metal debris.
Inspect the distributor cap contacts to see if any spark marks are more of less in the middle
of the cap's proper "contact zone". If not, you've diagnosed an internal misalignment, which
you know how to correct.
Posted on Sep 14, 2011
Dishwasher won't run
Mar 13, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Vxl 3s turns on when i plug in battery, green light comes on, than red, than blinks through the racing and training modes, wont respond with button push
It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
Programming Your Traxxas Electronic Speed Control
Oct 17, 2012 | Traxxas Velineon VXL-3m Speed Control
CANNOT GET GREEN LED ON 2218 TRAXXAS RECEIVER
Hi I am having problems with my 4x4 slash 1/10 scale
When I turn on the vxl-3 and that turns green but the traxxas link goes red for 3-4 sec then starts blinking red can anyone help please
Jul 07, 2012 | Traxxas Link 2.4 Ghz 5 Channel Receiver...
I just got a traxxas stampede in dec. i have used it about ten times and now i am having issues when i go to turn it on the green light on the esc comes on and then goes to red and then the light goes off...
make sure ur batteries are fully charged and ur using the right ones for ur model reset ur transmitter to factory default, it sounds like the esc is detecting something wrong when u go to use it bad battery if its a lipo may have ran it to long which can mess them up, I would clean the button on the esc really good, if the truck is making that noise the esc will try to shut down the system if all else fails send in ur esc to traxxas and they will send u a new one for like $50 buck let me know if u get it going
Aug 22, 2017 | Electric Traxxas Stampede Xl-5 Rtr ...
My ps3 is hooked up and everything it comes on but it won't come up on my tv screen, BUT EVERYTHING IS HOOKED UP, The hdmi cable is plugged in to
Please do the following steps to reset your PS3 display :-
Turn the PS3 off into standby mode (red light on)
Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Wait for the PS3 to detect your HDMI cable.
Hope this helps and thank you for using FixYa
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
How can you adjust a traxxas rustler for a novice driver so it doesn't go so fast?
When turning on, press and hold the button on the ESC until it flashes 1, 2, 3 times then let go of the button. You are now in novice mode.
Dec 24, 2010 | Traxxas Stampede and Rustler Vxl
How do i reset my rc traxxas stampede?
I don't believe the reset (or syncing) is necessary on this model. However, on similar models you pull the batteries from the vehicle and the remote. Wait 30 seconds. Replace with fresh (or tested as good) batteries.
Best regards
Mike
Nov 20, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
I started setting up an intel d865perl today and i'm pretty sure i did everything right, i followed diagrams read manuals and such but when i plug in the power cord it immediately starts and there a green...
1. There is a BIOS SETUP setting to "automatically start after a power outage" -- this is useful for "servers".
2. If you press and HOLD the power-button for TEN seconds, the computer should shut itself off.
3. Turn the computer off, disconnect the "data" cable to the HDD (hard-disk-drive) and then turn the computer on. Does the HDD lamp still light-up?
4. Do you get any on-screen video when it starts to start-up?
Sep 02, 2010 | Intel D865PERL Motherboard
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Toys Logo
52 people viewed this question
Top Electric Toys Experts
Lawrence Oravetz
Mike Stager
Mike Stager
Are you an Electric Toy Expert? Answer questions, earn points and help others
