Garden Logo
M
Michael w Berdy Posted on May 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2016 husqvarna yta18542 lawn tractor the bar that attaches to the forward reverse pedal came off by the transmission where does it attach to the transmission
barn2897
Level 2:
Habit-Forming:
New Friend:
  • Expert 153 Answers
  • Posted on Nov 27, 2019
barn2897
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
153
Questions
0
Helped
67355
Points
428
Hi Michael-
I found this youtube video.
https://www.youtube.com/watch?v=JLbRR9bxgZA&list=PLsYoN2fs0wwfgxccGfpiZA2bMQuFCv5aD
I also found this link regarding owners manual (OM) for your lawn tractor.
https://www.husqvarna.com/ca-en/support/manuals-downloads/
Hope these help.
5 Related Answers
mickey813
mickey813
  • 472 Answers
  • Posted on Oct 15, 2009
SOURCE: Troy bilt lawn tractor that will not go in forward-just grinds
sounds like the trnns has some thing lose in it you will need to get to the shop
Anonymous
  • 41 Answers
  • Posted on Apr 11, 2010
SOURCE: Was mowing when it just stopped going forward. It
Under the mower below the seat of the rider, at the rear of the tractor, look up and you will find the transmission there. There is a belt that runs on the pulley under there, and this belt can slip off when it gets worn or stretched. Sort of a tough spot to get to but, that is most probably cause.
Let me know,
Chip
mickey813
mickey813
  • 472 Answers
  • Posted on May 08, 2010
SOURCE: After stopping, tractor does not engage in forward or reverse
sounds like the by pass rod has been pulled out
Anonymous
  • 253 Answers
  • Posted on Jun 28, 2010
SOURCE: Hydrostatic transmission on murray select lawn
Without more info, inspect drive belt and tensioner assembly from engine to tranny.
montecdub
  • 12 Answers
  • Posted on Sep 05, 2011
SOURCE: Troy Bilt Horse Lawn Tractor Transmission problems
you need to screw the transmision adjustment in so that it is push all the way in to gear.
Husqvarna YTA18542 moves forward very slowly
ever check the fluid level . they do not like air .
Husqvarna YTA18542 is running well, but only in reverse. I have checked all the fixes I could find, but was wondering about the release switch that
It's possible that the loose release switch could be causing the issue with the mower only running in reverse. When the release switch is not properly engaged or disengaged, it can cause the mower to think it is in neutral, which may prevent it from moving forward. You may want to try tightening or adjusting the switch to see if it helps.
However, there could also be other issues with the transmission or drive system that are causing the problem, so it's important to thoroughly check all components and consult the manual or a professional if necessary.
2helpful
Lawn tractor won't go forward or reverse
If the engine is running normally and the drive belt between the engine and the transmission is in good shape, most likely you have a failed hydrostatic transmission.
My 2008 Troy Bilt Pony lawn tractor will not engage in iether forward or reverse. No clear reason just stopped working. The transmission locks up and the tract or will not start either (probably because it...
Make sure the brake pedal is fully depressing. Check the linkages for the forward / reverse and brake pedal. Check for grass build up causing the linkages to bind.
Nov 26, 2017 • Garden
2answers
The drive pedal is stuck forward and wont budge along with the brake pedal...
Drop mower deck and have a look.
Both rods run to the rear on the right side.
Possibly something interfering.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
