Caroline
most likely oven got too hot
Is it a Fisher and Paykel electric oven ?
If it stays on the oven after it cools down
remove the power to the oven
may have to flick off circuit breaker or pull the fuse to oven electrical circuit.
Wait 30 seconds and flick on circuit breaker or put fuse back .
Built In Oven Fault Codes F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
If your appliance is newer than 1996 F0 error
code is a stuck key pad .
To verify turn off power and access the
control panel and remove the ribbon connector that goes from key pad to
control board .
Now restore power.
If the F0 code goes away you'll have
to replace the key pad .
If it stays it means the control board is bad. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
The F0 usually means that there is a problem with the keypad.
My solution for the F7 problem may help. You will find my solution at the following link.
http://www.fixya.com/howto/h155050-dreaded_f7_error
I have now shared my fix with over 1600 folks and most report success. I hope that it works for you too. Please let me know at: [email protected]
