What are the best settings for the mic to suit a male baritone voice
Eq for male vocal mic on mackie 1604 vlz3
There is no easy answer to this. It will depend on the mic, the speakers and the singer and genre amongst many other things. It will also probably be room dependent too although the overall eq should be able to take this out of the equation to a large extent.
Your best bet is to get someone to sweep the frequency on the mid range with a bit of positive and then a bit of negative eq to find where most affects your vocals then fine tune to your liking. Are you using a bit of reverb/chorus/echo as his can often, when used sparingly, enhance even a good singer. The biggest difference you'll probably find is from using different mics. The ubiquitous SM58 does not suit everyone but is robust, warm and forgiving but if you're after a more pure sound there are many more accurate mics you can try.
Aug 10, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
Why does it sound so bad?
It's probably the mic, or you have some mental condition. I'm going with the mic, try returning it and getting a new one and if there's no difference, then try the software you use on whatever it is you're recording it with.
May 27, 2013 | CAD Microphones GXL2200 Professional...
When i open my messanger and find someone to video call with its says my mic worksa dn it worked the frist time nd now the second time it can "hear" my voice
Make sure the webcam mic is set as default - this is especially important if you have a laptop with a mic or use a headset with mic
Typical audio set up
Laptop with mic x webcam with mic x Vista x Yahoo Messenger 10
If you have an earlier OS, you may have to access your hardware from the Control Panel.
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Video and Voice
Set webcam mic and speakers to show Default equipment
Open Video and Voice Setup to test audio equipment
Click 'Place a free test call'
Check box 'Allow USB devices to access Messenger'
Click 'Apply' click 'OK'
Jul 30, 2010 | Logitech QuickCam Messenger Web Camera
LifeCam VX-1000 Webcam: i can't get any voice responce. I have checked ev...
If you have a laptop and a webcam you have 2 mics - you need to set your webcam mic as default.
TEST SPEAKERS
Restart computer
Configure audio to the chat program
May 17, 2010 | Microsoft LifeCam VX-1000 Webcam
My yahoo messenger voice call pc-pc working but the other side can never hear me! But if I use skype no problem. It used to work but may be because I changed my wireless router to Belkin! But I also turned...
Try running through your settings again
TEST SPEAKERS
Restart computer
May 15, 2010 | Yahoo Messenger
I just bought a live! cam voice and when i install the cd that it came with it says unable to install driver. so i went to their website and dl the driver n installed but now the problem is the mic doesnt...
Check your computer audio settings to make sure the webcam mic is set as 'default'
Plug in webcam
TEST SPEAKERS
Restart computer and configure to your chat program
Mar 18, 2010 | Creative Labs Live! Cam Voice Webcam
Microsoft vx 1000 i cant get the audio to work on a vista computer
TEST SPEAKERS
In lower dropbox display "Use this device - enable" click OK
Restart computer
Jan 30, 2010 | Microsoft LifeCam VX-1000 Webcam
I try to record a voice message with lifecam vx-1000 but when I try to playback to check the message I don't hear anything. I have checked all the volumes & they're all fine. so why can't I record a...
Set up Audio example
Laptop x webcam/mic x Vista x Yahoo Messenger
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Restart computer
Dec 13, 2009 | Microsoft LifeCam VX-1000 Webcam
No mic detected
try to check the mic volume on the program that your using. look for the settings of it. like in YM there is a test for mic to configure the minimum and maximum level that fits and suited on your hearing sound.
CHARCOIS
Oct 21, 2008 | EliteGroup P4VMM2 Motherboard
Laptop's Audio does not work in voice chat
There is a specific download for this. Your best bet is contacting Yahoo and asking them where to find it.
Jun 25, 2008 | Dell INSPIRON 6000 CENTRINO...
20 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
