Question about Refrigerators
How to adjust two devices at bottom of door? - Refrigerators
  • samuraj
    samuraj May 22, 2019
    What is your fridge?
I have a meld wen vinyl slider that I am trying to install but I cannot remove the bottom metal track so I can install the window
You need to adjust the wheels up with the adjustment screws on the bottom end of the door. The door will lift slightly enough to let the wheels and door clear the track. So up and in. Then when replacing, lift up and set down on the track on the rollers and adjust up turning screw so that the door rolls easily without rubbing. Some doors adjustment screw is on the bottom door end, some are on the side of the bottom of the door a few inches back, depending on model.
Sep 03, 2016 | Cars & Trucks
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
The bottom freezer door on my Kenmore refrigerator 795.7900 pops open each time I close the top door. I have tried adjusting the leveling screws and it hasn't helped. Any suggestions?
Glen you keep adjusting but before that try to find this unusual problem. On its own, doesthe freezer door close witha thud? If not it needs adjustment otherwise other problems could surface.
Mar 03, 2014 | Kenmore 72912 / 72914 / 72919 Bottom...
Sub Zero - 700 TCI 2 :Water is forming on bottom of Frig.
Most refrigerator doors are adjustable. You may find that adjusting the door so that there is a proper seal eliminates the water collection problem
Sep 12, 2012 | Sub-Zero 700TC Bottom Freezer Refrigerator
I have a Northland freezer/fridge side by side unit. Model # NM118. The door on the refrigerator side is not properly aligned with respect to the door on the fridge side. The refrigerator side door is...
Start by making sure the box is square -- that the doors are perfectly parallel across the top, with respect to the outside of the box. You fix that problem by adjusting the front feet on the fridge to square up the box. If the doors are all square and the fridge door is still low, look for some adjustment in the bottom door bracket - may have some slots where you can loosen mounting screws and adjust upwards. This may take two people or a lever (maybe a piece of lumber) as you have to raise the door while you're making the adjustment. OR remove the top bracket, remove the door and set it aside then try adjusting the bottom bracket and replacing the door and top bracket.
Feb 28, 2018 | Northland Refrigerators
There is gap in the bottom part
a gap in the bottom part of what ? if its the freezer door just adjust the door up if its the two top doors with a gap at the bottom of the two doors adjust and the hinge's and ajust both the same .. mm //
Aug 17, 2010 | Amana AFB2534DE Bottom Freezer French Door...
Bottom door was not shut all the way, now it is
on the bottom door hinges there are bushes to adjust the hight they wear out in time,, if you take off the hinges on this door you can "pack out" the door hinge with steel washers to adjust the hight there by lifting the door up a little
Jun 27, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Decor double oven - Door adjustment
Unfortunately yhe door hinges are non adjustable.
The only solution is to replace the hinges as a pair.
Hope this helps.
Dec 15, 2009 | DCS WOS-230 Oven
Window adjustment on a boxster where and how
Inner door panel off and adjustment is where glass/channel bolts to regulator to move glass backwards and forwards. To adjust top in and out 2 10mm bolts in bottom of door to adjust bottom of regulator
Aug 28, 2009 | 1999 Porsche Boxster
Door is rubbing at the bottom of fridge. Can it be adjusted?
there is a kit that goes at the bottom hinge that will lift the door
Apr 17, 2009 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
