Cameras Logo
Posted on May 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to skip a color with memory card - Cameras
Tony Parsons
Level 3:
  • Cameras Master 6,405 Answers
  • Posted on May 22, 2019
Tony Parsons
Cameras Master
Level 3:
Answers
6405
Questions
Helped
1652373
Points
20272
I'm sorry, I have no idea what you mean. Are you using in-camera image processing ?
1helpful
2answers
What are the card meanings in uno flip
Here are the meanings of some key cards in UNO Flip:
Flip Card - When played, it causes the direction of play to reverse from clockwise to counterclockwise or vice versa.
Skip Card - Skips the next player's turn when played. The turn then goes to the player after them.
Draw Two Card - Forces the next player to draw two cards from the deck in addition to their regular turn.
Wild Card - Acts as any color of the player's choice. Helps them get rid of a card when they don't have the color played.
Wild Draw Four Card - Similar to a Wild Card but also forces the next player to draw four cards in addition to their turn.
Reverse Card - Reverses the direction of playback to the way it was before a Flip card was played.
+2 Card - The next player must draw two cards and their turn is skipped. Stacks with other +2 cards.
Color Change Card - Allows the player to change the color played to any color they want.
So in summary, these special cards either change the direction of play, force other players to draw from the deck, act as wildcards, or change the color played on a turn. Strategic use is key. For detailed pverview you can visit link in comments
May 26, 2019 • The Toys
Unable to read memory card after dropping camera
And you think that is the only problem?
The first thing I should try, is remove the memory card and read it on my computer. Use an external card reader.
If the card still holds pictures, reinsert the memory card and try again.
I don't know if the camera was on, while you dropped it. Because if on the right moment the camera was still writing to the memory it hit the floor, the complete file system can be corrupted.
If you can't read pictures on the external card reader, you should first try to recover all the pictures, because there is a reasonable chance, the pictures cam be recovered, even if the file system is corrupted.
Some errors on memory cards or pictures can be corrected with some recovery programmes, but not every error can be corrected. free software to recover your files on a memory card:
http://www.memorycard.freedatarecoverysoftware.org
www.cardrecovery.com www.wondershare.net with free trail
www.cardrescue.com with free evaluation version
If there are no important pictures, or no pictures at all on the card, you can skip the recover part. Just format the card with FAT 32. When placed back in the camera, do a format with the camera.
Success. I hope this is all damage on your camera, but ????
Jan 21, 2014 • Cameras
I am unable to get my "Copy to Card" function to work. The words appear, but they are not in bold letters, and my down-up button completely skips the function when I attempt to copy photos from...
The only reason I could see such a basic function failing to work, is the memory card isn't inserted. It's unlikely that this is the case, but just check to make sure.
Mar 07, 2011 • Cameras
In uno, can you lay two different colored skip cards down in a row?
Hello dirtrider. The official rules state: "Skip" - When a player places this card, the next player has to skip their turn. That said, if there are only two players, the answer to your question is yes. IF however, there are more than two players, each player gets a turn before you can lay down that second card. Joe
Thanks for choosing Fixya!
Nov 23, 2010 • Toys
Unable to read my memory card, it seem to be memory slot problem
i need to open my SanDisk M2 memory card, but my card reader is unable to read it. please help. there are important files on this memory card. thanks in advance..
3helpful
Mobile unable to read memory card and giving information that "memory card not formatted"and then sain"operation failed" pc is also unable to detect
Initially check whether the memory card is working fine.To ensure it use it in other mobiles.If the memory card is working fine means remove any password set in memory and check in your mobile.Then check the memory card in your mobile if the problem persists Memory card IC is the problem.
Most probably the problem is the memory card .
Jun 29, 2010 • Cell Phones
13helpful
Canon a590 Card (not really) Locked
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
1helpful
8 gig micro sd unable to format
you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
3helpful
Memory card locked
my memory card locked, i am unable to open my memory card, how can i open?
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
