Question about Yamaha Boating
How to fix a leaking Yamaha 15 hp enduro 15dmh outboard 2 stroke outboard
  • Yamaha Master
  • 1,497 Answers
What's leaking? More info would help.
Posted on Jun 16, 2019
SOURCE:
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
SOURCE: My 81 yamaha enduro is smoking badly
Same happended to me with exactly the same motorcycle... I solved the provblem by replacing the crankshaft oil seal on the rightside of the crankcase. It solved the problem immediatly!
Posted on Aug 08, 2009
alicantecoli
  • 22484 Answers
SOURCE: 40 hp mariner outboard 2 stroke oil leak at
without seeing it in front of me its difficult to advise,i had a mercury but it wasnt oil injection so i iam not sure exactly how this injection system works but i should imagine its nothing more than a O ring thats perished or a copper washer needs cleaning with some wet and dry.I bought a new 4stroke mercury in the end because i got fed up with fuel consumption from the 80hp two stroke ,this four stroke 50hp will do about 12 14 nautical miles to roughly 6/7 litres of petrol at about 1200 rpm because iam only a sunday driver and the bumping on the waves makes my back ache unbearable,Well this is the land of fiesta /siesta /manaña --spain .Have a closer look and see where its leaking its only a mechanical pump running off the engine ,so it will have a push rod with some sort of diaphragm that pumps a tinysquirt of oil into the crankcase so it can mix with the incoming fuel ,nothing complicated
Posted on Sep 17, 2009
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
  • 53 Answers
SOURCE: I have a 2002 ox66 Yamaha 2 stroke 250 hp std
Prop shaft. You have to remove the bearing housing cap. reference number 70. Remove the bearing housing. reference number 60. The bearing housing will need to be pulled out buy using a puller. If it was in salt water it can be difficult. Pull the prop shaft and clutch dog assembly.
Posted on Nov 18, 2009
Testimonial: "Thanks i will try."
Yamaha 2 stroke 15 hp outboard won't start. Hasn't been used in several years. Using new gas. leaking gas, will turn over, but won't start
Hey Janine,
The carb(s) is/are stopped up.. they need a complete cleaning and setting... Any qualified professional can handle this job,, - Even a professional two-cycle motorcycle mechanic can do this job)
Jun 28, 2017 | Yamaha Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
May 11, 2013 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Boating Logo
54 people viewed this question
Top Yamaha Boating Experts
Colin Stickland
Colin Stickland
Mike
Vincent G
Vincent G
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
