Cell Phones Logo
Donna Mcie Posted on May 22, 2019
How to input APN number in T8 smartwatch - Cell Phones
1helpful
3answers
Is there a find-fucntion for a name in the Phonebookof a CHOXI 2.0 smartwatch
Questions, Troubleshooting Help & Support Page 3 - Fixya
www.fixya.com/troubleshoot/page-3
Get free troubleshooting help, expert advice, repair guides & DIY tips for all ... Is there a find-fucntion for a name in the Phonebookof a CHOXI 2.0 smartwatch.
Smart watch reviews - Consumer Reports
www.consumerreports.org/.../smart-watch...gadget/ind...
Consumer ReportsConsumer Reports labs tests and reviews new smartwatches. ... as LG and Motorola throw their smartwatches in the ring, along with Samsung, ... Check out ourSmartwatch buying guide for helpful advice to find the best smartwatch for your needs. ... apps that control functions such as music and the camera on your phone, ...
Jan 09, 2016 • Cell Phones
What is the battery number for the Torgoen T8 (it takes 3 separate batteries
Hi all, :)
the T8 has the following movement and uses these batteries
Ronda 585 Using Renata battery 362
Ronda 751 x 2 pcs Using Renata battery 379
so it uses three (3) batteries in total :)
4helpful
2answers
How to activate gprs of my cherry mobile phone model T8
Hi
Although Globe does not support the handset, you can still try to configure your handset for the MMS/GPRS using this general configuration setting to serve as your guide.
GPRS Access Settings
APN (Access Point Name): internet.globe.com.ph (postpaid)
http.globe.com.ph (prepaid)
Homepage: http://www.globe.com.ph/globe.wmlc
Bearer: GPRS
Proxy Address: 203.177.42.214
Proxy Port: 9201
MMS Access Settings
APN: mms.globe.com.ph
Bearer: GPRS
MMS Center: http://192.40.100.22:10021/mmsc
Gateway Address: 192.40.100.20
Gateway Port: 9201
May 24, 2011 • Cell Phones
Replacing old flor 48" tubes
There are three types of fluorescent 48" bulbs t 12, t8, and t5. they are not interchangable. if you have a fixture that has a t12 type ballast, it will not light up the t8 bulbs. you have to change the ballast to a t8 style. just to clarify, the number stands for 10ths of an inch in diameter on the bulb. a t12 is 1.2 inches, a t8 is .8 inch and a t5 is .5 inch.
1helpful
I have sony ericsson w880i and the not access to the 3g internet
This sound like you need the APN settings sent to your phone.
You will need to phone your network provider (probably free from your phone)
Tell them you have no internet access and ask them to send you the APN settings
This will come via text and you just click install, they may give you a pin number to input when you install settings, if you need this they will tell you and explain when to put it in.
If you have the right APN settings and it still does not work you need to set the Mobile web settings in your phone as your default access point this wil be done in settings and connections
1helpful
LG Viewty email set up
1 Find "Access points"
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press Access points.
2 Create new or edit existing data connection
  • To create a new data connection:
  • Press Add.
  • To edit an existing data connection:
  • Press the required data connection.
  • Press the icon to the bottom left.
  • Press Edit.
  • Press the Connection title input field.
  • Press C to clear the input field.
  • Key in EMAIL GPRS and press OK.
3 Select data bearer
  • Press the Bearer drop down list.
  • Press UMTS or GPRS.
  • Press OK.
4 Select authentication
  • Press the Authentication drop down list.
  • Press PAP or CHAP.
  • Press OK.
5 Enter username
  • Press the Username input field.
  • Key in user and press OK.
6 Enter password
  • Press the Password input field.
boxAdd('info6', cBoxClosed); The APN name must be in lower case letters. 7 Enter APN name
  • Press the APN input field.
  • APN same as your internet settings
8 Save and exit
  • Press Save.
  • Press Disconnect to return to stand-by mode.
Please note: You now need to select settings for an email profile.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
