Question about Timex Watches
Does Timex dual tech have back gasket - Timex Watches
2 Suggested Answers
SOURCE:
dunnbiker
  • 8546 Answers
SOURCE: How do you set the digital time on the Timex
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Posted on Feb 23, 2011
I have a timex iron man watch. It jumps ahead 2 hours on occasion. Another time it jumped back 2 hours. what can I do?
There appear to be many versions of this watch. The first think I would check is the instruction book. It may be dual time zone? Amazon ca timex ironman Timex Watches
Sep 30, 2015 | Timex Ironman Watches
Rubber gaskets for timex watches
The rubber gasket is the waterproof seal, to get the proper one you need to go to Timex or an approved repairer!
Nov 02, 2014 | Watches
What is chrono in timex adventure tech?
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
http://assets.timex.com/user_guides/W215_M179/W215_M179_NA_EN.pdf ??
Feb 07, 2011 | Timex Expedition Adventure Tech Compass...
How do you set the digital time on the Timex Ironman Triathlon Solar Dual-Tech watch?
Nov 20, 2010 | Timex Ironman Triathlon Solar Watch T5G691
How do i put the back on a timex watch?
The best way to do it to avoid damage to the crystal is to use a case back presser which you can find on ebay at reasonable cost. Be sure to replace the rubber gasket too - even if it looks OK - to ensure water resistance. Once compressed a gasket should not be reused.
Apr 21, 2010 | Timex 27191 Wristwatch
The analog hands of the watch are slower than the digital watch. Is there a way to synchronize?
There should be! If you haven't got instructions for your watch, you can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Apr 03, 2010 | Timex Ironman Solar 50-Lap-Dual Tech...
I cant get the hands to move on my iron man 42 lap dual tech watch
This watch has two batteries in it, one for the digital display and one for the analog movement. Chances are you just need to replace the analog battery, which is under the larger digital battery.
Aug 15, 2009 | Timex Ironman Triathlon 42 Lap Combo Dual...
Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
hi
please follow the steps to change the battery
  1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
  2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
  3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
  4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
  5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
thank you....
Apr 08, 2009 | Timex T41091 Expedition Watch
Timex expedition compass battery replacement?
hi
i am not an expert in this particular case but i followed theses below steps . here are they.....
Unscrew the case back with a case back tool (aka Jaxa wrench) which engages
the notches in the case back. I'm assuming the watch has a screw back - if
it has notches it does. Pop out the old battery.
In some watches you have to
unscrew a clip but in most the battery pops right out. Examine movement for
evidence of battery leakage or other damage. Carefully clear away any crud
at the edge of the case - the tiniest metal shaving will short out the coil.
Install new battery of same type. Handle new battery with non-metal tweezers
or rubber gloves, never bare fingers. Inspect case back gasket or preferably
just replace it with new o-ring of same size. Gasket should be lubricated
with silicone grease. Reinstall case back using wrench. If you are
concerned with water resistance the watch needs to be tested in a pressure
test machine. I'm sure the pros have more tips but this should suffice for a
Timex where it would not be a big loss to damage or break the watch.
i hope you can successfully replace the battery
thank you
Sep 06, 2008 | Timex Digital Expedition watch
Watches Logo
32 people viewed this question
Top Timex Watches Experts
freddyfox
Jerry Greenberg
Jerry Greenberg
Dustin
Dustin
Are you a Timex Watch Expert? Answer questions, earn points and help others
