Home Logo
G
Gary Wayne Posted on May 22, 2019
I am looking at an Uberhaus Bola Baltique Neo-Round shower stall 31", but have seen reports about the wheels on the door rusting. How can this be prevented?
mehan
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 19 Answers
  • Posted on May 23, 2019
mehan
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
19
Questions
Helped
10023
Points
39
Silicone spray often, keep clean.
5 Related Answers
Lucky Cash Register
  • 90 Answers
  • Posted on Sep 26, 2009
SOURCE: I have a motherboard failure. Part # N7551BH-31
I have a working sharp M/B for 125 bucks
Chris
Anonymous
  • 617 Answers
  • Posted on Jan 02, 2010
SOURCE: How do I keep the Escutcheon on my Moen shower
http://www.jelmar.com/CLRbasic.htm
This is the best stuff for that rust,it's strong stuff,so wear gloves while using.It's available just about everywhere,shopping centers,hardware stores,even your local Wall-Mart.
Mike
  • 4383 Answers
  • Posted on Sep 05, 2010
SOURCE: I have a Maax steamer Shower with a sliding door.
A hardware store will have replacements, if not go to Maax website and order there, replace them all.
Anonymous
  • 1998 Answers
  • Posted on Dec 21, 2010
SOURCE: We have a 1-year-old Maax
sorry it took so long for someone to answer your reply some of us live around the world and are at different time zones glad you were able to find the brakets Take Care and as they say in Hawaii around this time Mele Kalikimaka or have a Merry Christmas
Rick
Anonymous
  • 528 Answers
  • Posted on Mar 06, 2011
SOURCE: The double roller assembly on
That part is Maax only, you will need to go through them or a dealer in your area.
http://www.maax.com/Corpo/DocumentsTechniquesCorpo.aspx
I have Uberhaus shower door and panel. Can the panel be cut. Is it tempered or safety glass? I need help on this. Thanks.
I Would check with a local class company if this can be done . And if they would do it .
Feb 09, 2018 • Plumbing
Uberhaus bathtub and shower faucet 81585016 problem
The reason is because they built this wrong and Rona still decides to sell it. I have one in the wall that I am stuck with. Call up Mecanair, the rep for uberhaus and the they will tell you its not a mistake to have HOT water come out when the handle is at the C position.
Mar 06, 2013 • Home
Leaking Neo-Round shower stall???
Check really close to make sure there is not a small crack in the base. Many times they can barely be seen and when you stand in the shower they open up larger allowing water to leak out. You may have to have someone else stand inside while you look for the crack.
Maax neo round stall leaks where base meets wall
Many times there are small cracks in the panel or the base. It may not be able to be seen until someone is standing in the shower.
Nov 04, 2012 • Plumbing
Maax neo round shower stall continues to leak at bottom where it meets wall. Keep recaulking. Same results.
Many times there are small cracks on the material, it can be hard to see but opens up when someone is in the shower.
How do I keep the Escutcheon on my Moen shower faucet from rusting yet keep it clean? How do I get the stains from the rust off my shower stall wall?
Hi we just bought a maax breeze neo corner shower how do i install the two back walls do you use glue or what?
There will be a nailing flange on the walls of your shower. Typically, drywall screws are used on this flange on the top portion and along outside edges spaced 6-8" apart. Use a high quality tub/shower caulk down the seams.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
