SOURCE: spool comes out one end and wraps around trimmer bottom: Grasshog gh700 model electric dual line
Yes, the lines should spool in the same direction.
SOURCE: WEEDS ARE WRAPPING AROUND THE
That is a common problem with many trimmers... not much you can do about it...except be more carefull and go slower so the weeds fall down before getting caught by the line and getting twisted around the shaft...
heatman101
SOURCE: Polaris Freedom ,I had fishing line wrapped around
somewhere on the accelrator line there is still melted fishing line i recommend checking the whole accelrator cable or the line had also gotten into the shaft cassing so remove whole casing cut off all the fisahing line and if its still there it should be melted so you may need a chissel
