Tv will not power up. standby light just keeps on blinking
6 blinks is usually the D board
Doorman45, common failure for your model, replace both IC`s with the following number stamped on the top of the IC,
MCZ3001D, the new & improved version ends in DB but I have installed the originals several times with no call backs, good luck
same problem
doesn't power up, standby light blinking sometimes it will work if i unplug it for a while but it needs to be fixed. thanks for your help
need to know where i purchase the new chips? can anyone help
doesn't power up, standby light blinking sometimes it will work if i unplug it thanks for your help
I have the same problem what is IC in the solution stand for and were are they at?
no picture on set... 6 blink code... was working intermitently for a while but, no more...
TV immediately shuts off when I turn it on. No picture just clicking sound.
While beyond frustrating, it is at least good to know this is a somewhat common problem. We haven't been able to watch this TV in about a year for any length of time. It will not power-on for weeks, and then one day, we'll get it to come on and stay on for a couple of days. Neither husband or I have "handyman gene", so can someone please elaborate more about changing-out D boards, replacing IC's (what's an "IC"?)... Repair costs we've been quoted are OUTRAGEOUS. Keep in mind, there is no such thing as explaining it too simply. ; )
Thank you!!
I'm having the same issue. Standyby mode blinks 6 times. Does anyone know of a solution - and the cost to fix. Is it worth fixing?
no picture ...standby keeps blinking
what is a ic
