Question about Honda Garden
MY Honda HRX 217 mower has stopped engagin the blades
5 Suggested Answers
SOURCE:
  • 93 Answers
SOURCE: I have a honda xrx 217 mower. the left rear height
Just spray it where it adjusts with WD-40 or better rust remover. Get good stuff at your Auto Supply Store. Let it work overnight and your problem should be solved.
Posted on Sep 14, 2009
  • 389 Answers
SOURCE: parts for a honda lawnmower hrx 537
It would depend upon WHERE in the world you are located but you should be able to contact your nearest Honda Mower dealer or do an internet search for
>> "hrx 537 honda parts" << and it will return quite a few places both on-line and in-person place where you may purchase them
Posted on Oct 12, 2009
  • 1116 Answers
SOURCE: I am having to replace
Your answer can be found at the link below on page 44. This will walk you through removing the cable and the settings for adjustment after replacement
http://www.hondapowerequipment.com/pdf/manuals/31VH7001.pdf
Posted on Jul 31, 2011
H2_Brad
  • 425 Answers
SOURCE: Honda mower engine oscillates when idling. Check it out: http://www.youtube.com/watch?v=HbmtcyPR2DM
The carb needs to be cleaned. The main jet and nozzle are the areas to pay attention to. The main jet screws into the carb in the same spot that the float bowl screw goes into. The nozzle sits above that and if you tap the carb (carefully) on the bottom once the main jet is removed the nozzle will drop out. Use a small piece of wire to clean all the small holes in the jet and nozzle. Make sure they are open and free of clogs. This is a common problem with all small engines.
Posted on May 20, 2012
Down load free repair nanual for honda hrx 217 vka lawn mower
Go to HondaOwners Manuals and download one
Feb 21, 2017 | Honda Garden
Want to change drive cable on my Honda mower hrx 217
if it's old enough you'll have to get the kit. 06225-vh7-305. on the trans there's a lever that the cable attaches too. if it's a barrel type it needs updated. if it's a loop style then its the newer style. If you don't have the proper tools you might want to have a Dealer do the work. will save you the headache.
Feb 17, 2017 | Honda Garden
Have new starter motor for honda hrx 217 starter won,t engage
Possible missing teeth on flywheel. Bad bendix or clearance discrepancy.
Mar 15, 2014 | Honda Garden
Hi there, I've bought a honda hrx 537 21 inch mower cheap because the previous owner went over a tree stump and although cuts well, it vibrates when just idling-without the blades spinning! could this just...
sorry to tell you this but that will never go always . It has a bent crankshaft usually right by the blade. It will need to be rebuilt with a new crankshaft. Oh, use can use it like it is, but your hands will fall asleep with vibration.
Oct 13, 2013 | Garden
Honda lawn mower not pulling hrx 217
Clean pulleys, replace belt.
May 21, 2012 | Honda Garden
May 19, 2012 | Honda Garden
Need to replace the rotostop .
I found the manual from a french dealer .
Thanks for help .
Nov 02, 2009 | Garden
Parts for a honda lawnmower hrx 537
Oct 11, 2009 | Garden
Garden Logo
27 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
