Count number of Delivery Status
To count textual values, use the countif function; the syntax is =countif(range,criteria). So, if your range, for example is B3 through B100 and you want to know how many cells contain the status value Delivered, put the following in the cell you want the count to show: =countif(b3:b100, "Delivered"). Do the same thing for each of your other status values in the cell that you want the count to appear.
Note that this requires each status value to be spelled correctly in each cell. I'd recommend assigning shorter values, say 1 through 5 or A through E to avoid that -- unless the values are being generated automatically so the spelling is guaranteed correct.
Hi Kathleen MacDonald, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
