Televison & Video Logo
I need a remote control for a Bush TV lt19micwa
5 Related Answers
Anonymous
  • 291 Answers
  • Posted on May 12, 2008
SOURCE: locked my lcd bush
!st-Try this...... Unplug the unit for about 3-4 hours, it shoul go back to nornal_DEFAULT...
Hopethatworks.
Anonymous
  • Posted on Sep 02, 2008
SOURCE: Sky remote control code for Bush TV
your code is 1239.
Anonymous
  • Posted on Feb 02, 2009
SOURCE: bush tv remote code
i have a bush lcd tv 27 inch an its stuck on stand by i have an urc7740 one forall remote how can i take my tv of stand by with this remote.
Anonymous
  • Posted on Mar 10, 2009
SOURCE: URC22B universal remote controller 15 in 1
081,119 or 026
worked on my bush dvd/tv combo tv part
Anonymous
  • 74 Answers
  • Posted on Mar 14, 2010
SOURCE: How do I find out the code to use my remote with a bush tv?
hi
bush codes are one of the following,1916,0294,0556,0714,1900,0698,0617.0614,0217,0208,0487,1037.
0361,0264,0374,0363,0355,0282,0371,0037,0036,0009,0163,0218,0668,
regards Derrick
I need the tv code for a bush BMKDVD40 for a universal remote control
The TV code for the Bush BMKDVD40 for a universal remote control is 0376. You can usually find the code listed in the manual for your universal remote, or you can search for the code online by typing in the model number of your TV.
1helpful
Where do I find the model number for a Bush dled32hds TV
Using the model number of the TV, DLED32HDS, and replacement remote control leads to several replacement remotes for sale that will work this TV. One option is https://www.amazon.co.uk/Replacement-Remote-Control-Compatible-DLED32HDS/dp/B08H8V4S5C . Another is https://www.remotesca.com/products/replacement-rc4391p-remote-replacement-for-bush-dled32hds-dled49fhds-tv .
I hope this helps.
I HAVE BROKEN MY TV REMOTE FOR A BUSH HD READY DIGITAL PLASMA TELEVISION MODEL NUMBER PT42GY638EB
It will be very difficult to get a universal remote control for this set. You have to contact the authorized service center for Bush at your town, to buy a new original remote control.
2helpful
I need codes for a one for all tv remote URC 11-1660 R01
This remote control has no setup code for Bush TV to synchronize with.
2helpful
Hello, I have a Bush TV 2038TSIL which I want to start using as a second TV. Since the TV hasnt been used for a while I'll need to do the tuning again. Can this only be done with the remote control...
Hi
If there is a "Menu" button on the front panel of your TV, you can enter into its menu; surf trough and come towards tuning option. If there is no such button on the front panel of your TV, you have to buy one universal remote control to work with it. Be sure that buying new remote have setup codes for Bush TV. There are very rare remote models have setup codes for Bush Tv. Look at its manual before buying it. OK.
2answers
Bush tv remote code
did you get this sorted? Im having the same problems with my tv and that remote!!
Remote control code list
The Konig IR9982 is not a universal remote control so there is no code to make it work your Bush TV. It is actually a direct replacement (electronic clone) remote for some Hitachi models.
You will need a direct replacement for your particular model, try http://www.remotesreplaced.co.uk/television/remote-control-bush.htm
10helpful
2answers
Bush tv remote code
Top Bush Televison & Video Experts
matt martin
matt martin
Sean Wright
Sean Wright
john h
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
