Question about Garden
I can't gets attachments to attach on the PoulanPro PR25. They won't go in far enough. I even pulled the coupler off and the new or old attachment still won't go into the shaft far enough.
I finally got it to work. I just got some leverage and pushed as hard as I could to force it in.
5 Suggested Answers
SOURCE:
reddevil6
  • 1673 Answers
SOURCE: attachments
Most likely will have to replace either the nozzle valve or the hose comes complete, so if the nozzle pieces are available, then replace the complete hose asm.
Posted on Jan 05, 2008
  • 32 Answers
SOURCE: pull cord won't rewind
the shaft isnt attached right.
Posted on Jun 12, 2009
barbaraepper
SOURCE: Have a 28CC Husqvarna 2 stroke engine. Used it once, now the attachments won't slide far enough in to connect to the drive shaft and
Sounds like the upper drive shaft connected to the trimmer housing has slid down. Try holding the unit gas tank down, and turn the inner shaft until it drops back down into the unit, then attach the desired tool.
Posted on Jul 24, 2012
hazard123_99
  • 4 Answers
SOURCE: flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
Posted on Dec 07, 2012
How to connect powercord to recoil
Hi Ken:
Here's a youtube clip.
https://www.youtube.com/watch?v=iOI1UQDb8Ns
The principle is the same for most pull start motors.
- Take it apart (remove the starter assembly)
- Pull the cord out as far as it will go.
- Use a nail or screwdriver to stop the spool from rewinding
- Remove the cord
- Install a new cord the same way that the old one was attached
- Remove the nail (or screwdriver
- Re-attach the starter assembly
Ta Da!
Jan 08, 2016 | Garden
Need to replace radio antenna on a 99 isuzu rodeo
I just replaced the antenna on our 02 rodeo. No need to remove radio or anything in dash. This is how I did it.
First you will need access to back of fender, enough room for your hand. Open hood and remove 3 bolts running along top of fender, open passenger door and remove top bolt holding fender. Gently pry top of fender away from vehicle. Place object in gap to hold fender ( I used the head of a rubber mallet). Reach inside fender and disconnect old antenna, follow cable through wall into passenger compartment. Gently pull cable from behind carpet and unplug old antenna from coupler. Connect new antenna to fender ( replacement antenna I ordered was slightly smaller than opening so I had to add washer). Run new antenna cable through wall and plug into coupler. Re-attach fender
Aug 23, 2012 | 1999 Isuzu Rodeo
Jun 28, 2012 | Husqvarna 28cc Gas Line Trimmer
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
How do you replace a 1998 toyota avalon xl exterior door handle?
You have to remove the inner door panel to access the exterior handle's mounting nuts. Once you have the panel off, there will be a plastic film, or water shield, that you can peel off far enough to reach the handle ( when done, reseal the plastic with a little adhesive).. The handle is usually held in place by just two nuts which you remove, then disconnect the latch rod from the handle, and pull the old handle off. Attach the rod to the new handle, tighten the attaching nuts, and put everything back together. Getting the door panel off is the hardest part of this job.
Good luck.
Mar 06, 2012 | 1998 Toyota Avalon
I am looking for a new coupler for my InStep Pathfinder 12-PF250 bike trailer. How do I get a new one?
Hi bethiel.
Here Amazon com Coupler Attachment you can choose between many models. (before order something ask the seller if fits on your bike)
hope this was helpful...
enjoy choosing :)
Aug 28, 2011 | InSTEP Pathfinder Bicycle Trailer
Headlight replacement on a 1991 pontiac grand am
Sealed Beam Type
  1. Disconnect the negative battery cable.
  2. Unfasten the headlight bezel attaching screws, then remove the bezel.
Remove the headlight bezel
To avoid turning the vertical or horizontal aiming screws, refer to the illustration before removing the headlight retainer.
  1. Unfasten the headlight retainer attaching screws, then remove the retainer.
Remove the headlight trim screws then...
... pull the trim off while holding the bulb
4. Pull the headlight out, then carefully detach the electrical connector.
Pull the bulb out far enough to disconnect the wiring
To install:
  1. Attach the electrical connector to the new headlamp.
  2. Place the headlamp into the socket.
  3. Install the retainer, then tighten the attaching screws.
  4. Connect the negative battery cable, then turn the headlight switch on, to be sure the headlights are operating.
  5. Install the headlight bezel and secure using the attaching screws.
Jan 18, 2010 | 1991 Pontiac Grand Am
How to replace just the Kirby 210097 Hose End For G5 Series Vacuum Cleaner to hose. can buy replacement but can not get the broken end off
simple and rquires no tools. Fill your sink with hot water and set the end in water with attachment on it. Within a few minutes the end is soft enough to slip out.
setting the hose end in the water again will let you simply slip the hose into the new attachment with ease.
Nov 24, 2009 | Kirby G5 Bagged Upright Vacuum
What is the gap spacing between the ignition module and the flywheel for a PoulanPro PPB2000 blower/vac?
0.010-0.012" or a 'quick tip': you can use the cardboard of the box the coil came in, or the parts tag that may have been attached to it. Those should be close enough to get you going.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 13, 2009 | Poulan Garden
KENMORE 90
There is a part between the motor and gearcase called a coupler, the clicking happens when it cracks. Easy way is to pull the machine foreward and tilt it back to expose the bottom. Clips hold a pump, has two hoses attached, then a motor, unclip wire harness on left and any other attached, mark these extra wires if it has them. The motor has two clips supported with two 1/4 in hex screws, Now you should see the coupler, a rubber donut and two three pronged plastic flanges attached at gearcase and motor. Use a 1/2 socket to flush the new coupler flanges on both sides and the rest is a experience.
Aug 25, 2008 | Kenmore 22422 Top Load Washer
Garden Logo
24 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
