Question about Garden
My lemon cyprus tree has crispy brittle needles? Its been inside over the winter so i am trying to bring it back to green again. Can it be saved or is it gone?
2 Suggested Answers
SOURCE:
  • 53745 Answers
SOURCE: My lemon tree is full of fruit ,leaves are green with yellow marks on them,doesn't look healthy.What to do?
shortage of mineral in the soil
could be manganese, borax, or other items found in a citrus tree fertilizer
talk with a nursery showing them a few leaves
Posted on Jan 31, 2018
Lemon tree has blossoms but never lemons
You need lots of trees, lots of blossoms, plus the 'birds and the bees'. You know they need pollinating, one flowering tree doesn't work?
Mar 27, 2018 | Garden
Bumps or growths on lemon tree
this is bad -
see
http://www.sgaonline.org.au/citrus-gall-wasp/
had a lemon tree in Victoria it would have been 30 years old was starting to get this wasp. My brother in law lost a lemon tree from this as it sucks the goodness out of the lemons and the tree.
Feb 24, 2018 | Garden
My lemon tree is full of green fruit but some of the leaves are turning yellow and curling,some are green with yellow spots.What to do?
This will happen, - if the Tree needs feeding, you may find it needs an acid type of Feed +Soil - also where you are keeping the potted tree usually better at this time of year under cover eg greenhouse, also check the leaves for bug infections.
Jan 31, 2018 | Garden
Leaf curl on my Meyer lemon
Generally Meyer Lemon Trees need water every one to two weeks. ... If the leaves are drooping like they're too heavy for the branches, and turning dark brown or black the tree is getting too much water. If the leaves are crispy and dry or curl upwards this is a sign of under watering.
Meyer Lemon Trees: 7 Secrets for Loads of Fruit ' Fast-growing-Trees ...
Citrus Leaves Are Curling - What Causes Citrus Leaf Curl
https://www.gardeningknowhow.com/edible/fruits/citrus/curling-citrus-leaves.htm
Dec 29, 2015 - As far as fruit trees go, citrus tend to be the low-fuss member of the team; but when curling citrus leaves appear, you'll need to intervene. This article will help that. Click here for more info. ‎Citrus Fruit Brown Rot · ‎What Is Horticultural Soap · ‎What Are Psyllids: Tips On ...
Leaf Curl - Four Winds Citrus Problem Solver - Four Winds Growers
https://www.fourwindsgrowers.com/solving-common-problems/leaf-curl.html If the leaves on your dwarf citrus are curling, there are three common possibilities: Some insect pests will cause some leaf curl. In spring, aphids might do this on soft new leaves. ... Overwatering can cause leaves to curl or cup INWARD.
Why Are the Leaves on My Meyer Lemon Tree Curling? ' Hunker
https://www.hunker.com > ... > Garden & Lawn > Pests, Weeds & Problems May 6, 2010 - Pests. A number of insects can cause leaf curl in Meyer lemons. The most common and likely is the everyday whitefly, but aphids, citrus leaf miners, and mites are also common culprits. Insects are a larger challenge to manage than over-watering.
Meyer lemon Leaf curl Google Search
Jan 29, 2018 | Garden
What is the Treatment for diseases of lemon trees
To treat, remove all infected leaves and dropped fruit from the ground. Prune the lower branches from the tree, those that are more than 2 feet from the ground. Then spray with a fungicide such as Agri-Fos orCaptan. Botrytis fungus - Botrytis rot is yet anotherfungal infection which may afflict lemon trees.10 Jan 2016
Lemon Tree Problems: Treating Common Lemon Tree Diseases
https://www.gardeningknowhow.com/edible/.../lemons/common-lemon-tree-diseases.ht.. What is the Treatment for diseases of lemon trees Google Search
Oct 24, 2017 | Treatment Garden
When do I prune a lemon tree
losing the year's yield. Lemon tree pruning should occur after it has produced the fall harvest to give it plenty of time to recover prior to the next season's harvest. If you live in a warm climate, you have a bit more leeway on exactly when to prune; just don't do it when it's roasting hot. For everyone else, February through April are the best pruning months. On the whole, however, you can prune any time the tree is producing flowers.
Read more at Gardening Know How: Lemon Tree Pruning: When Is The Best Time To Prune Lemon Trees https://www.gardeningknowhow.com/edible/fruits/lemons/lemon-tree-pruning.htm Cutting Back Lemon Trees Learn When And How To Prune Lemon Tree
Jun 10, 2017 | Garden
My lemon tree is a mature tree full of fruit ,the fruit this winter has been rotting on tree ,we have had enormous rains all winter and gooing into spring is this the problem as hasn't happened before
Lemon trees are extremely sensitive to over watering, only thing you can do is make sure you have good drainage. Dig channels at low points to make sure ground water moves away. Just a small point, you posted your question on the Cars & Trucks section, you may be missing some better solutions by posting here, however, I've raised a few lemon trees in Spain and in my front room in London so I have a little experience in this area.
Good luck
Oct 06, 2016 | Cars & Trucks
I live in the northeast, can a mini pomegranate tree survive the winters?
The tree should have no problem surviving the winter as long as it is in a pot that you can bring in side. During the cold months, the tree should be brought in and put next to a window, preferably the sunniest one in your home. As soon as it starts to warm up, bring it outside. Mini pomagranates tend to blossom and produce fruit in late June/July/August.
Aug 05, 2013 | Garden
Garden Logo
16 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
