Hoe do i prgrm my I.R echostar remote
Cam i program my echostar remote to work with my jvc amp
4 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: Echostar 5.0 remote
https://rweb.echostar.com/departmental_content/TechPortal/content/tech/remotes/5.0.shtml
Posted on Jan 03, 2009
SOURCE: how to program a echostar technologies remote to
my volume do not work on my 2nd tv
Posted on Mar 12, 2010
  • 20 Answers
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
Posted on May 30, 2010
Using a echostar 1223475322-aa ir remotehow to program to tv this remote does not have pound key and no sat key or device keys how to progeam to tv
If your EchoStar remote does not have the keys you need, you will have to try using a remote that does have them.
Jan 31, 2017 | Televison & Video
I have a universal control and i don't have the codes for it to work the tv
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    Jumbo Universal Remote Control ยท 8 Device ... Programing codes for the remote. If you do not see your device listed, you can use the code search feature to program the device into the remote. TV Codes ... JVC, 013,054,055,060,065,067,089.โ€ŽGuide to Programming the ... - โ€ŽDownload the Manual - โ€Ž8 Device Learning Jumbo ...
    What is the universal control remote code for a JVC television?
    www.ask.com > Technology > Television & Video
    JVC universal codes can also be found on the instruction sheet or manual guide that comes with the remote control or television set. If these universal codes do ...
    JVC Remote Codes
    remote-codes.findthedata.com/l/163/JVC-Remote-Codes
    A list of TV, HDTV, DVD, Receiver, Audio, Amplifier and and VCR remote codes forJVC. images for codes for universal remote control jvc
Jan 03, 2016 | JVC AV-32D305 32" TV
How do I reprogram my compustar remote to my 2003 Pontiac Montana EXT SE?
Hi Melissa
I have this procedure for Pontiac, try it
  • remotes you will be using on the vehicle. Once you program the remote. all previous remotes that were programmed will be erased from memory. The other remotes will not be functional until you program them again.
  • 1. Remove the key from the ignition.
  • 2. Remove the "BCM PRGRM" fuse from the fuse panel. Use the legend on the fuse panel to properly locate the "BCM PRGRM" fuse. Fuse panel is accessed by opening the front passenger door.
  • 3. Close all of the doors.
  • 4. Close the liftgate.
  • 5. Insert the key into the ignition, and turn to the ACC position.
  • 6. Turn the key to OFF and then back to ACC within 1 second.
  • 7. Open and close any vehicle door. A chime will be heard when the system enters into programming mode.
  • 8. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
  • IMPORTANT: After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
  • 9. Repeat step 8 now for each additional remotes to be programmed including any existing remotes.
  • 10. Remove key from ignition.
  • 11. Install the "BCM PRGRM" fuse back into the fuse panel and test remote(s).
Good Luck
Apr 11, 2014 | Cars & Trucks
Is it possible to program a new keyless remote without a dealer? Where is the cheapest place to purchase them. I asked a dealer locally, and the cost to purchase the remote was ridiculous!
Cheapest place I find is the Salvage Yard for only $5.00. The bad news is that to program the new remote, you need a tech2 scanner to set that up. Most Transmission shop has a Tech2 scanner now and i am sure you can get them to help you program the new remote for a much better price then the Dealer.
The scan tool is necessary to enter the programming mode on the newer vehicles. There just isn't any other way to do it. Your's being the first year, you may get lucky that you can reprogram it with this instruction which is the 2005 Montana's reprogram.
IMPORTANT: Before entering programming mode, have in possession all of the remotes you will be useing on the vehicle. Once you program the remote. all previous remotes that were programmed will be erased from memory. The other remotes will not be functional until you program the them again.
Good luck and thank you for using FIxya.
Jul 01, 2010 | 2005 Pontiac Montana SV6
Remote start function on remote doesn't work for a 2005 Pontiac G6.
Replace battery first and see if that help, if not then follow steps below, if you cant figure it out or it still doesn't work, or take it to the dealer, it could be remote module is faulty. Keep the windows open as a safety measure, then,
Remove the ignition key from the ignition lock cylinder.
Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block in Wiring Systems.
Close the liftgate.
Turn the ignition lock cylinder to ACC.
Turn the ignition lock cylinder to OFF, & then back to ACC within 1 second.
Open & close any vehicle door. A chime will be heard when the system enters the BCM programming/diagnostic mode.
Important
Press & hold the transmitter LOCK & UNLOCK buttons simultaneously for 14 seconds.
Repeat the previous step on each additional transmitter to be programmed.
Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block in Wiring Systems.
Oct 07, 2009 | 2005 Pontiac G6
Press 'Menu'
May 25, 2009 | Akai LCT3201TD 32 in. LCD Television
Echostar 5.0 remote
Dec 26, 2008 | Universal Remote Control Activity Based...
CANT GET TOSHIBA CT 90302 TO PROGRAM
I had the same problem, and the solution above/below that says to use code 018 worked for me. Yeah!!!
Sep 01, 2008 | Kenwood RC-R0720 Remote Control
I need the code for an echostar remote ir103602
How to Program a EchoStar Remote Control
Instructions
Step1
Ensure that the remote control has new batteries installed. If you are not sure or have been using the device for a while, go ahead and insert fresh batteries. You need four AAA batteries.
Step2
Locate the mode buttons on the controller. You will see SAT, AUX, TV, and VCR. SAT stands for the satellite receiver. Your remote is automatically set up to work with your EchoStar receiver, and you do not need to program it for this function. AUX may refer to a cable television device or an audio device that hooks it into your stereo system. TV refers to your television set. VCR may be chosen to control a standard VCR or a DVD player.
Step3
Press the mode button that corresponds with the device which you want to control with the EchoStar remote control. For example, if you want to program the remote to control the TV, press down the TV mode button.
Step4
Turn on the device. This is the item you want to control with the EchoStar remote. You may need to do so manually or with its own remote control. In this example, you would turn on your television set with its own control.
Step5
Press down the EchoStar mode button for the device again, but this time hold it down for three seconds. You are going to notice that all the other mode buttons are going to flash on. Aim the remote at the device you want to control.
Step6
Depress the EchoStar remote power button briefly and then slowly click either the up or the down arrow button. You are performing a code scan that allows the remote control to run through all the preprogrammed codes that are stored in its memory. Proceed slowly and do not hurry this process. It may take a few minutes, but it is virtually foolproof.
Step7
Stop when the appliance you want to control with the EchoStar remote control suddenly turns off. You have hit upon the correct code, and if you save it now, your remote will be able to use it in the future to control the functions of the item.
Step8
Store the code in the EchoStar remote control’s memory by pressing the pound button. You will notice that the corresponding mode button is going to flash, acknowledging the programming choice. You are now ready to control the item with the EchoStar remote control.
Aug 28, 2008 | Televison & Video
REMOTE CONTROL
What the make and model number of tv?
Mar 15, 2008 | Zenith ZEN425 Remote Control
19 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
