SOURCE: freezing up TD-64-24 beverage cooler
Some of this TRUE don't have service valves, but you can put a tapping valve (A1) in the appendix (small piece of pipe comming out of the compresor and seal on the other end).To check the pressure you need to know what type of refrigerant is in the system .If is 134a the low side should be about 24psi and the high around 160 it could vary depends how hot is inside the place and the fridge but not much more than 200.If you working with R22 pressures be around 60 low and 250 high side.
SOURCE: Avanti Beverage cooler gets too cold
Hi, sounds to me as though your temperature control is faulty, and the unit is running all the time. This control will have to be replaced. This is something you can do if you take your time and draw a wiring diagram in case you forget. It will have a long coiled up wire with a bulb on the end of it mounted in the evaporator section in the refrigerator section. This all comes out together. This is the only thing that would cause this problem. Get all of the numbers, model, serial, and part numbers when you go to the appliance parts house to get one. You should have no problems in doing this. Please keep me posted as I am sure this unit is worth changing out the stat.
Sincerely,
Shastalaker7
