Question about Garden
How do i fix limp mode on my boom trike?
Usually happens after slowing down then riding at a slower speed
SOURCE:
Tin-of-Spam
  • 27 Answers
SOURCE: elec. fuel injection / harley davidson
Sounds like a knackered / flat battery. Check the battery, look at the terminals and make sure the wires to the battery are connected properly. If the battery is good then check your charging circuit.
Posted on May 23, 2008
  • 5 Answers
SOURCE: gear shifting slips
sounds like the schimano nexus hub i would take in to a good bike shop and have look at it
Posted on Apr 28, 2009
  • 363 Answers
SOURCE: 2003 300M drops into limp mode
Transmission !!!!!!!
Posted on Jul 23, 2009
SOURCE: 2003 Jaguar s-type 4.2 -- Engine fault, parking
i have a jaguar s type 2003 and out of no wear it is writting to be park break fault and the park break does not working what i can do to solve this prob.
Posted on Jan 16, 2011
afarri
  • 1386 Answers
SOURCE: Vehicle drving alright then goes
Hello and welcome to FixYa!
You have a new battery right? As a first course of action, please remove the positive battery connector and let it sit for atleast 10mins. Reconnect the positive battery connector and turn the key on ON position then OFF, do this 10 times and on the 10th crank the car. Take it for a few runs and observe how it goes.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Jun 08, 2011
What is limp mode
limp mode is a system built in the ecm or pcm that will allow your vehicle to drive at a slower speed when the ecm or pcm detects a problem so that you can stop at a safe location or drive to your mechanic, when the problem is fixed the ecm or pcm will allow the vehicle to drive normal again. hope this helps,
Jun 28, 2014 | 2002 Dodge Grand Caravan
How to fix limp mode
The ABS system may cause a vehicle to go into limp mode if it is defective. Most times that will happen if your ABS light is lit up on your dash board!
Apr 18, 2014 | 2004 Volkswagen Polo 1.4
Mtdproducts com
This most often happens when you are mowing too much grass at once, or when the deck (or chute if you have a bagger) is clogging for some reason. Sometimes this is made worse by having dull blades. Usually mowing at a slower speed or mowing more frequently will help solve this. If the motor is struggling with the blades, these are usually the culprits. Clean your deck thoroughly, cut the lawn more often, or cut it slower.
In some cases, if your PTO belt may be worn, stretched, or need adjustment. When this happens, the motor will not slow down with the blades but will keep running normally and you may smell a burning rubber smell as the blades slow down.
Jul 16, 2013 | Garden
Have a Chrysler Concorde, 2001. I can drive it a little ways and as i begin to slow down most the time I hear a big boom like noise (like a huge balloon, but deeper in sound) and then it stays in 2nd gear...
You need to have the TCM scanned for codes. Autozone can only give you the ECM codes. You have code 0700 listed. That means there are codes in the TCM. When the TCM has a code in it, it goes into limp mode and locks the Transmission in 2nd. You might have a bad speed sensor.
Jul 14, 2011 | Chrysler Concorde Cars & Trucks
Kenmore washer aggiates slower than when new. is
Usually, there are two agitator modes. A Normal ("Fast") mode, and a delicates ("Slow") mode. Put washer in 'delicates' cycle and see if the agitator slows down even further. If it stays at same speed as in perma press or 'normal' mode, then there is an open in the circuit betwixt the controller dial and the agitator control.
Feb 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Ovewrconfident
the last couple rides I've been recognizing in myself some overconfidence. Both times I hadn't ridden for a maybe three or four days and getting on the bike my ummm exuberance at being back on the machine translated to some questionable judgement and actions on my part. The last time put me into a situation that scared me a little bit and forced me to cut my ride short and go home earlier than I had planned. I've ridden aproximatley 5000kms in this my maiden riding season. These last two weeks I didn't ride much at all and both situations arose during this two week period. I'm wondering if I should ride more or ride less to keep from getting reckless. Does anyone have any tips about this? Any recomendations? Thanks in advance.ve found it helpful to go back to a parking lot and review the slow speed maneuvers--because going down the highway in a straight line at higher speeds gives me false confidence. Slow speeds remind me of how much I have to learn about balancing the weight of the bike, and how clumsy I still am with the clutch, brakes, and throttle. Rolling Eyes It's not enough to just get through the exercises, now I want to be as smooth as possible, and make these turns tighter and tighter, and go slower and slower. Usually has two benefits: gets my head back into being present and aware, and replaces my confidence with real skill-building. Now, if I would only do it more often.,,,
Nov 10, 2008 | 2006 Highland Dirt-Track
When your driving down the road at 55 mph it will slow down like its got no power. The speed will reduce from 55 to 25 and it feels like it is going to stall out. In the meantime,I have my foot on the...
need more info? is car missfiring or has been missfiring? does it happen when cold? or hot? and how much fuel does car have in it? does it happen when less fuel or more fuel or know diffrent? cant help
Oct 11, 2008 | 1998 Plymouth Grand Voyager
Xtype
Hi,you might try just to disconect your battery for five minutes ,this will reset your computer and may solve the problem, Good Luck
Jun 27, 2008 | 2004 Jaguar X-Type
Garden Logo
22 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
