Question about Health & Beauty
What tools do i need for my hoveround mpv5 - Health & Beauty
SOURCE:
SOURCE: How do I lock up my Hoveround MPV5?
1. Turn the controller on.
2. To lock the chair, depress and hold the ON/OFF button. After one second the controller will beep. Release the ON/OFF button. Move the joystick forward until the control beeps. Move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is locked.
3. To unlock, turn the control system on. The speed/response indicator will be rippling up and down. Move the joystick forward until the control beeps. Then move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is unlocked.
This is from the manual, I hope it helps you.
Posted on Jun 28, 2009
  • 103 Answers
SOURCE: Where might I buy a new joystick controller for my
You need to contact hoveround. Only Hoveround dealers can work on hoverounds and get their parts.
Posted on Dec 16, 2009
SOURCE: my mpv5 hoveround has lights that go on, but
My father in law has a hoveround and it is in the lock position but we can't remember how to unlock it.
Posted on Jun 08, 2010
HoverTech
  • 232 Answers
SOURCE: Online owners manual for Hoveround MPV5
The full manual is not available online. It must be purchased directly from Hoveround for $20 plus shipping. Please call 800-964-6837, you will need the serial number from your power chair, located inside the manual brake release above the footrest.
Posted on Oct 29, 2010
HoverTech
  • 232 Answers
SOURCE: My Hoveround mpv5 will not turn on charger states
It sounds like the batteries have gone bad and need to be replaced.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. When you turn on the power chair, nothing happens. The charger will indicate the batteries are full, but instead of being full of pwer, they are full of crud. Your warranty will most likely not cover replacment as this is due to customer neglect, but your insurance may still cover the replacement if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own, type U1, 24v 33 amp, found at Batteries Plus, Insterstate Battery or any other battery warehouse for $75-120 each.
To replace the batteries:
Remove the black power cords behind the battery covers by squeezing the plastic pinch clip. Remove the cover carefully by unhooking the black webbing strap so that you do not yank any of the leads. Using a 7/16" wrench loosen the bolts that attach the leads to the posts, be careful if there is any corrosion that may irritate your skin. Check the fuses to make sure they are still good; if not they are regular automotive fuses that are inexpensive and can be found at any auto parts store. Remove the plastic caps or any packaging from the new battery posts and seat the batteries on the tray, connect the leads to the posts as indicated and tighten with the wrench. Place the batteries back ont he tray, reconnect the power cord, Replace the covers, and tighten the straps.
You may want to use the power chair until the battery is used up before you charge it fully for 8-12 hours; this will ensure that the battery gets FULLY cycled and any buildup inside the battery from it sitting on the shelf in the store is burned out. Make sure that you charge the power chair after a full day's use for 8-12 hours (overnight), not after every trip as overcharging can cause damage. If the power chair in not going to be used for a while, continue to charge the batteries at least one day a week to keep the batteries fluid.
Return your used batteries to the battery store or auto parts store for proper disposal. Good luck!
Posted on Nov 02, 2010
How to locate and replace a fuse or fuses in a Hoveround MPV5
Here is te user manual to replace the battery where you can also find the fuse:
https://www.hoveround.com/Hoveround/media/Document-Library/how-to-install-batteries-for-mpv5-mk3-power-chair.pdf
May 03, 2017 | Health & Beauty
Hover round mpv5 , what size wench to remove tire
To remove Drive wheel 15mm 17mm 19mm are normal sizes, to separate the split rim for tire replacement, 7/16, 3/8. I would use a socket set.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 28, 2016 | Hoveround MPV5 Electric Wheelchair - Used...
Wt is the tire psi for mpv5 middle tire
The pressure is 50 PSI, but 45 PSI worked better for me.
Sep 30, 2014 | NRS Hoveround MPV 5 - Used Power...
How do you change batteries on hoveround mpv5 ?
Disconnect cables going from battery boxes to the control box. There is probably a catch that needs to be squeezed in, then pull and wigglt the connection block until it disengages. Release the straps over the battery boxes then remove batteries and covers. Lift up on the cover (you may need to push some cable back into the box) and put cover aside. Disconnect cables from batteries and attach to the new batteries. Same procedure, in reverse, gets you back to an operational MPV5.
Sep 27, 2014 | Hoveround MPV5 Electric Wheelchair - Used...
Oct 28, 2010 | NRS Hoveround MPV 5 - Used Power...
LOOKING FOR CONTROLLER FOR HOVEROUND MPV5
Those are only available through Hoveround and retail for around $1159.00. You may want to have a Hoveround Tech come out to diagnose the power chair for $50 to make sure that is what you need before spending that kid of money.
Aug 27, 2010 | NRS Hoveround MPV 5 - Used Power...
I need. a manual for the Hoveround MPV5
These are available directly from Hoveround for twenty dollars plus shipping.
Apr 07, 2010 | NRS Hoveround MPV 5 - Used Power...
I lost the Hoveround MPV5 manuals
Hello. Call the company directly to get what you need
1-800-542-7236
Mar 22, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Where can I get a manual for a Hoveround MPV5 wheelchair? I bought a used one, but no manual.
This manual is a hard one to get. You will have to call Hoveround. If you would like, Click the link below and it will take you to Hoveround's web site.
http://www.hoveround.com/wp/products/power-chairs/mp5-power-wheel-chair/
Feb 07, 2010 | NRS Hoveround MPV 5 - Used Power...
Where might I buy a new joystick controller for my mpv5 hoveround scooter.
Nov 22, 2009 | NRS Hoveround MPV 5 - Used Power...
Health & Beauty Logo
18 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
