Marantz 1608 settings to allow Dolby vision and hdr pass through to Sony x900f tv
4 Suggested Answers
SOURCE:
  • 905 Answers
SOURCE: No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
Posted on Oct 06, 2008
BMOE77
  • 5 Answers
SOURCE: I have a Yamaha HDR
Each of the modes are true surround sound. Some are newer and may have advantages/disadvantages depending on personal preference. Prologic is the oldest of the listed, followed by dolby and dts. You can perform a google search to see the differences in dolby and dts but they should both be equally good. I prefer dts.
Posted on Dec 23, 2008
  • 24 Answers
SOURCE: ps3 to marantz receiver to sony brava lcd tv
Loop the ps3 through the tv and out to the receiver. You only need audio going to the receiver.
Posted on Jun 18, 2009
Does Fire Stick Support 4K ?
hi Ernest.
The previous Fire TV box already did 4K, but this one can now play it at 60 frames per second and adds HDR (high dynamic range) as a brand new feature to Amazon's streaming devices. ... Amazon has chosen to supportHDR10 but not Dolby Vision for HDR playback. On the audio side, the device offers Dolby Atmos integration.27 Sep 2017
Amazon announces new Fire TV with 4K and HDR for only $70 - The ...
https://www.theverge.com/.../9/.../new-amazon-fire-tv-announced-4k-hdr-price-date-20...
Is the fire stick 4k compatible?4K Resolution. If you have a 4K TV, the Fire TV will help you get the most out of it. This device supports a variety of apps in full UHD resolution, including heavy hitters likeAmazon Video, Netflix and YouTube. The Fire TV Stick, on the other hand, caps out at a full HD resolution of 1080p.27 Sep 2017Amazon Fire TV vs Fire TV Stick: What Should You Buy? - Tom's Guide
What makes 4k so special?A: 4K, also known as Ultra HD, refers to a resolution of 3,840 x 2,160 pixels. That's four times the 1,920 x 1,080 pixels found in your full HD TV.13 Sep 2017..
plus you could go to this link to help you out more.
Does Fire Stick Support 4K Google Search
Nov 18, 2017 | Televison & Video
Tip
Transfer/Edit Sony HDR-TG3 1080i AVCHD Videos on Windows/Mac Sony Handycam...
Sony Handycam HDR-TG3E is a super small camera with full HD recording on Memory Stick in 2008. It includes 4GB and 10x optical zoom for capturing 1920x1080 and 1440x1080 videos. However, this camera does not include progressive recording mode, which indicates that the HD videos are 1080i. Even though it is compact camera, the audio is recorded in Dolby Digital 5.1ch. You can also take 2.3Mp stills while you are recording video footage.
Sony HDR-TG3E features:
- 1920x1080i HD video recording
- 4 megapixel still photo recording
- Dual Rec simultaneous 2.3 megapixel still photo during video recording
- Handy face detection
- Carl Zeiss Vario-Tessar lens
- ClearVid CMOS Sensor and Exmor derived technology
Videos from Sony HDR-TG3E:
Movie Format:
- High Definition: AVCHD (1920 x 1080, 1440 x 1080) in .mts filename extension
- Standard Definition: MPEG2 in .mpg filename extension
Movie Quality:
- HD: FH (1920x1080i, 16Mbps) / HQ (9Mbps) / SP (7Mbps) / LP (5Mbps)
- SD: HQ (9Mbps) / SP (6Mbps) / LP (3Mbps)
Transfer & Edit Sony HDR-TG3 AVCHD videos:
For Windows users:
Install the Picture Motion Browser (PMB) from the bundled CD in box, and connect Sony HDR TG3 to PC via USB cable. Use Sony PMB to download HD .mts videos from camcorder to PC.
For Mac users:
You can capture and transfer Sony HDR-TG3 1080i videos to iMac/MacBook Pro via iMovie after connecting camera to computer with USB cable. However, you may face problem when trying to log and transfer AVCHD videos from Sony Handycam HDR-TG3E to Final Cut Express (FCE) 4 or Final Cut Pro (FCP) 5. After transferring HD .mts videos from camera to computer hard drive, just run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-TG3 MTS converter to deinterlace .mts videos and convert .mts to .mov for FCE and FCP, if you want to edit HD videos.
Alternative way to transfer HDR TG3 videos for Mac and PC:
Just connect HDR TG3 pocket camera to computer via the USB cable, and the HDR TG3 will display as a hard drive on computer. Navigate to the HDR TG3 hard drive to access the memory stick.
Tips: Sony Handycam HDR-TG3E is the model for Europe, and Sony Handycam HDR-TG1 is the model for US.
on Jul 14, 2010 | Cell Phones
Hdmi to component connection for surround sound
Does you tv have an optical audio output? That would be the easiest way.
Jan 07, 2013 | Marantz Sr8200 Thx Ex Surround Dolby...
I try to connect my BD player with HDMI port cable from BD player to Sony HT-DDW1600 Theater and from this receiver to TV (40? bravia). When I press BD button on the remote, picture comes out very good but...
Is your sony receiver HDMI pass through? some receivers dont allow audio just video through HDMI. Connect a digital coaxial cable from the dvd to the receiver and you should get true dolby surround.
Oct 28, 2009 | Sony MUTEKI HTDDW1600 Theater System
No surround sound when playing PS3 through HTDDWG700 via 2 HDMI
The HTDDWG700 does not transfer the audio through the HDMI cable that the vision goes through. To solve the problem i got an optical cable and connected the PS3 to the receiver with the optical and put the HDMI cable from the PS3 to the tv.
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
No video/display on TV when using sony str dh 500
If your set up is HDR-AVR and TV all you need to do is go HDMI out from HDR to HDMI in(Sat.) of AVR and monitor out HDMI (or composite video) to TV. and select the Sat. input on the AVR. The sound is only comming from the HDR in this case and the composite video or HD video is being switched out to the TV when you select Sat. on your AVR
Sep 20, 2009 | Sony STR-DH500 A/V Receiver
I have a Yamaha HDR 6030 system and have hooked it up to a bluray player on a HD 1080p tv. Which of the sound setting (prologic, dts, dolby etc) is the best one to use for watching movies?
Dec 23, 2008 | Yamaha HTR-6130 Receiver
Ps3 to marantz receiver to sony brava lcd tv
Aug 14, 2008 | Sony Playstation 3 (PS3) Console
here is more info
May 19, 2008 | Marantz SR-7200 Receiver
19 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
