Question about Power Computers & Internet
Singer Superb em200 embroidery machine won't turn on
Was embroidering and machine shut itself off. No error message, just powered off like the switch had been turned off. Unplugged machine and plugged into different outlets in the house, still wouldn't turn on. Unplugged from wall and removed power cord, let it sit overnight. Plugged back i, in the morning and still won't power on.
SOURCE:
techman
  • 3130 Answers
SOURCE: it keeps turning off
The audio output ICs or transistors are blown. Solid state elctronics are not very forgiving when they are shorted. it takes one tiny instantance and the componets will fry. sorry to be the bearer of bad news but you will need to have this unit serviced or replaced, And never ever work on any type of electronics with the power still on. Good Luck
Posted on Apr 08, 2007
snakehead
  • 1074 Answers
SOURCE: My machine won't turn on!
if your machine is on warranty take it back to the supplier you bought it from.or try to unplug the machine and plug it in back to go through its cycle and reset it self.if that does not work then you are having problem in the machine power supply.if you ran out of warranty, have a tech look at your machine.good luck.
Posted on Jun 17, 2007
salt56
  • 373 Answers
SOURCE: won`t turn on
Try leaving it unplugged for longer period of time. Look on the remote for any possible reset function. Try power button without the remote. If any ot these doesn't work there is a power supply module inside that malfunctioned. If under warranty contact where you purchased it. If not under warranty if you can get the module it is a simple plug up procedure.
Posted on Dec 31, 2007
SOURCE: Singer Quantum Futura CE-200 Problem
My machine did the same thing. I had several frustrated nights ans then it just started to work. Some suggestions that I had was that there may be dust where the units connect. Not sure what I did, but it worked.
Posted on Jan 02, 2008
Danmart
  • 291 Answers
SOURCE: Unit shuts off automatically after power on.
You have an internal short in the electrical line. your wall a/c [120 volts] goes inside and is converted [changed] to DC [ like a super battery] There are a lot of connections coming out of this POWER SUPPLY[super battery] to FEED other electrical circuit. ANY one of the circuits can demand more then power supply can give and will cause it to SHUT DOWN [turn off to protect itself]
unless u know what u are doing [" DANGER!! wILL rOBINSON, DANGER!!] you should not mess with it.
Posted on May 14, 2008
I got a singer futura 350 embroidery and sewing machine. This morning when i wanted to switch it on to embroid something the machine made a beep sound and all the lights is flikkering at once. Can anybody...
That is usually a warning that something on the machine is not set correctly to what you want. Consult your owner's manual and make sure that all settings are correct for embroidery.
Jul 18, 2018 | Singer Sewing Machines
How to deactivate the safety device on the Singer Futura SES 1000 embroidery machine? How can I get the hand wheel to turn again to get the machine to sew/embroider?
You can't--something is stopping the wheel from turning, and until you find out what is stopping it, your machine will be locked up. Take a look below the bobbin case, and you'll see a ***** holding a little door. It allows you to clean and see on the other side of the bobbin basket. Chances are, there's something like a broken off needle stopping the gear that turns the hook. It can also be caused by threads wrapped around the tension disks, or around the inside of the hand wheel itself. The hand wheel can be removed by removing the cap in the center--it is hiding a ***** that holds the wheel.
Feb 29, 2016 | Singer Sewing Machines
Singer 400 will not power on
Try turning the power switch on with the embroidery unit in place, insert the foot control. Then turn the power switch off, remove the foot pedal and turn the power on again. If that doesn't work, try inserting the foot pedal with the power switch in the off position, withdrawing it, then turning the power switch on.
Your motor was designed to shut itself down if it overheats or if stitching was interrupted. For instance, if your needle hit something solid and the needle bent or broke.
Generally, it will go on again in 10 minutes to 2 hours, depending on what the cause was. Occasionally, it can take longer. Using the foot pedal tends to reset the motor. I discovered this by accident one night, when I assumed that it was a Reset port and gently stuck the eraser end of a pencil in it until I felt resistance, then withdrew it. The machine had only shut down for about 3 minutes, but it turned right on again.
Jun 29, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Why is the fabric bunching into the bobbin when embroidering with the Singer Futura
bobbin thread is too high pressure or too low pressure on teh top adjustment!
remove bobbin and turn tension screw about 1/8turn left (anticlockwise) check if still grabbing, if so - top thread turn about 1/4 turn (at embroidery ir should do automatically, but sometimes need kick...).
check if it is still grabbing on the bottom, do it grab during straight? zigzag? double zigzag? if do not - setting on the pattern need to be look at. if it tangle as well on these three - need definitely servicing...
follow manual how to adjust.
Jan 09, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Futura 100 Embroidery machine...Need to cancel previous transmit
Had the same problem. Singer rep. solved this mystery in just min. after talking to her.
You can call singer company at 1-800-4SINGER. It will take a long time to get through, but they can talk you thru to resolve this matter. Or just visit singerco.com and go to F&Q section, #7 question.
Or you can email talktous@singerco.com (that's talk to us @ ...)
They answered my email the same day!
Hope this helps!
Jun 19, 2009 | Singer CE-100 Futura Computerized Sewing...
My start/stop switch will not begin sewing
Is the problem with embroidery only? If with both sewing and embroidery function and there is no error code (just 00) on the display, my wife experienced the same problem. There was an internal sensor that was bad. The sewing machine shop repaired with a new Singer part. Part was about $20, labor was $180.
Dec 23, 2008 | Singer CE-200 Quantum Futura Computerized...
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Jul 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Dec 27, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer futura ce-100 embroidery machine
Under the embroidery attachement (on the front side) is a lever to engage or disengage the "feed dog control." When embroidering, you need to move the lever to the level to disengage. The feed dog control should only be at the righe side position, or raised when you are not using the embroidery attatchment.
Jan 31, 2007 | Singer CE-100 Futura Computerized Sewing...
Computers & Internet Logo
23 people viewed this question
Top Power Computers & Internet Experts
john smith
vince
Gep Pep
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
