Question about Car Audio & Video
XCP410M RECeiver and CD Player and Tuner Mini Pioneer If your FM radio works shouldn't your AM radio work?
  • Car Audio & ... Master
  • 588 Answers
Hi Vale Savege, so you may have problems with the connection or the antenna cable
To receive AM, you need to have the connection and antenna cable correctly, while to receive FM, with a shorter cable you can do the same
I sent you the link to download the Service Manual
I hope you can solve the problem
Greetings Franco Dosil
Hola Vale Savege , por lo que comentas puedes tener problema con la conexion o el cable de la antena
Para recibir AM, necesitas tener la conexion y el cable de antena correctamente, mientras que para recibir FM, con un cable mas corto lo puedes hacer igual
Te envio el link para que descargues el Manual de Servicio
Espero puedas resolver el problema
Saludos Franco Dosil
https://usermanual.wiki/Document/XCP410M.742298536/view
Posted on May 22, 2019
SOURCE:
SOURCE: GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Posted on Aug 07, 2008
killer_clown
  • 86 Answers
SOURCE: hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
Posted on Oct 24, 2008
  • 71 Answers
SOURCE: Replaced radio with one from same model year. Displays Err 01.
this generally means the laser is either dirty or the cd player is shot, err 01 is a disc reading problem. Try cleaning lens with cleaning disc first if this does not help i would replace the unit with another. i would recommend replacing it with a cheap aftermarket stereo.
Posted on Nov 27, 2008
  • 79 Answers
SOURCE: Delco Cd player not working
look for a small hole normally on the facia,put a small screwdriver inside and press the reset button.hope this helps.
Posted on Mar 05, 2009
SOURCE: no sound from Insignia surround sound receiver from all inputs
no sound coming out
Posted on Oct 17, 2009
Pioneer cd player quit workin and i have static in radio could my fm modulator be bad and can that keep my cd player from working
Your modulator shouldn't effect the cd player. But it can cause static in your fm if you leave it on. Make sure the modulator is turned off before trying to use the regular fm. Also, if its a wired modulator, then check the antenna connections. If it's wireless than it should not effect anything. Depending on the radio, get a aux input on it. Wireless fm transmitters are the worst.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 25, 2012 | Car Audio & Video
Could some one tell me how to change the stations on my WURLITZER -MODEL WR 18-1015-CD AM/FM- 18" TALL-LIGHT UP i have tried to and i can not get it to work. It only has a remote. Thank you
Here is a link to obtain the owner/user manual for that wurlitzer if you would like it:
http://www.payphone.com/shop/instructions/Wurlitzerwr18.pdf
1. Turn power on using either the remote or power button located behind tuner door.
2. Push CD / RADIO BUTTON (25) to enable FM tuner.
3. Turn FM dial to desired station.
4. Position FM ANTENNA (16) for best reception.
5. Set volume to desired listening level.
Sep 17, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
No audio on my pioneer super tuner d eeq mosfet 50 w when it appears to be on???
the amplifier inside the unit has failed.
you can verify by hooking up an amplifier and using the RCA jacks for your signal.
If it works - the radio's internal amplifier is in need of repair.
Something will have caused the problem - so in the meantime - check the speakers for shorted wiring or burned voicecoils.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 28, 2009 | Pioneer DEH-P2900MP CD Receiver...
Will not tune any radio station, fm or am. everything else works fine. May be damage resulting from lightning, through the antena input.
It is very possible the fm tuner pack is damaged from lighting,if you have voltage going to the fm tuner pack im sure your tuner is bad pioneer part number for your tuner is AXQ7231
Sep 26, 2009 | Pioneer VSX-D811S Receiver
Need a manual for Manual Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
I need a manual for my DEH-P2900MP CD Receiver.
The unit is in a car that we have just purchased and the manual for the radio was not with the vehicle.
Jul 09, 2009 | Pioneer DEH-P2900MP CD Receiver...
How do i change it from FM to AM radio
just go to your radio tuner settings and change
the receiver from fm to am... so tat ur prob might get solved...
Thank you, kindly rate me...
Jun 29, 2009 | Pioneer DEH-2100 CD Player
Hello all;;;;;; i have a pioneer vsx-9500s,,,,the problem is i ran cable to my reciever so my fm radio will work but it doesn't,,,,,,,,i checked the cable on a tv and it worked ,,,,so i know the line is...
Nonsense. FM is included in MOST tv cable subscriptions- make sure your subscription includes this service. Do you have another receiver/tuner to test with?
Check all the connections between the cable entrance and your tuner; eliminate all splitters for testing. If you can get another tuner to work on your cable, it may be time to check into your tuner-
There is no difference in signal level between tv and fm- your receiver is not gonna burn up! If it has a 75-ohm cable input, use it!
Jan 04, 2009 | Pioneer VSX-D509S Receiver
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
