SOURCE: Husquavarna GT2254 runs fine till I try to engage the blades,
Hello janec37415:
>>From your Description it Sounds like the Seat Safety Switch is Bad, has a Bad Connection or the Stator/Charging Coils are Not Charging Enough for the PTO to be Engaged.
>>When the Blade is Engaged, the Seat Switch is Showing No One is on the Seat so the Engine is Shut Off by the Safety System or
>>When the PTO is Engaged and the Stator/Charging Coils are Not Charging Correctly, the Carburetor Solenoid Does Not get enough Voltage to Stay Open and the Engine Quits.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
SOURCE: Husqvarna yth2448 pto switch kills motor/battery will not charge
you may hav a bad alt. problem with the mower dying when you engage the pto is most likley a bad sensor or wire unplugged on the seat sensor.the way it works is if the blades are turning and it dosent sense you being on the seat the mower shuts down.this has been standard on mowers for quite a few years now. it keeps the blades from cutting you up if you fall off the seat while mowing. as for charging i would try cleaning the battery connections and get the battery checked first.
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch.
Good luck! Please rate my answer if helpful, thanks.
