The tractor had a cut out and have a new regulator to replace it also have a new wiring harness how to wire them?
SOURCE: need help wiring a max-e-therm heater.
red wire is other leg for 240.use whit ,black and green
SOURCE: wiring diagram for ignition switch farmall 140 tractor
FOUND YOU A WEB SITE FOR WIRING DIAGRAM
CARTER & GRUENEWALD CO. INC.
IF THAT DOSN'T WORK LOOK UNDER FARMALL 140 WIRING DIAGRAMS AND THE SITE WILL BE LISTED THIS SITE WON'T LET ME COPY AND PASTE TO YOU
SOURCE: 2004 toyota corolla tach wire
you can also solder the wire to the tach wire, this way it won't come off and cause a malfunction
SOURCE: 2002 ford escort zx2 negative ground harness
I am about to have the same problem with my 2002 ZX2. My shop called the Ford dealer and they can replace it for $450.00...
seems like an awful lot for a battery cable.
JS
SOURCE: i am converting farmall h tractoer electrial
If the kit contains a
wire and a diode, one would ASSUME it is a standard "3-wire"
alternator, rather than a less-desirable (goofy) "one-wire" unit.
Here's a simplified diagram.
Please note the diode, an "idiot light" or a 10 Ohm 10 Watt diode can be
used interchangeably in the "excite" wire lead.
