Question about The Health & Beauty
Location of the fuses on my ventura scooter. Have fully charged batteries in but, my off board charger doesn't light up. Before buying new charger I want to check fuses first.
SOURCE:
  • 7 Answers
SOURCE: razor e200 runs slow
you need a new battery they cost about 35$ on razor
Posted on Jun 08, 2009
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Posted on Jul 19, 2009
SOURCE: battery doesn't charge
i had the same problem so i took the battery out and pluged the moped in and it ran so i knew the battery had a prob then i took the battery out of the canvas case and it had expanded to the point were it almost leaked (exploded battery in other words)
Posted on Mar 19, 2010
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
  • 177 Answers
SOURCE: just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
Posted on Jun 05, 2010
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Green light does not come on the power charger
hi, there could be three reason for his .
following the instructions below for a external charger
1. the charger cannot see the battery voltage, this could be because a fues on the scooter has blown. the charger socket is damaged.
2. the Batteries never fully charge because they are damaged.
3. the charger itself has a fault.
I believe that scooter has the charge fuse locate on the tiller column,
Follow the instructions below for a built in charger, if that the case check the fuse on the battery leads,
Otherwise in my experience the batteries cannot be fully charged because they have a fault
Rarely is it the inbuilt charger that is faulty.
http://www.pridemobility.com/pdf/Owners_Manuals/INTL_Scooter/uk/UK_Celebrity_XL_om.pdf
Regards
Please give feedback...
Dec 16, 2012 | Pride Celebrity Xl 4 Wheel Scooter
Battery charger indicating that batteries are fully charged, but battery meter on the scooter shows no power at all. also the lights, indicaters etc arent working, im presuming that is resulting from the...
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Mar 14, 2011 | Pride New Mobility Victory XL 4 Wheel...
MY scooter battery needs recharged and I plugged it in and it indicatied it was fully charged and it wasnt. So I bought a new charger and that is showing the same thing. I dont know what to do next. The...
Has the scooter been stored unused for a while? If so, the batteries may have gone solid from improper maintenance. There is a gel inside the batteries that needs to have current run through it at least once a week to keep them fluid. The charger is showing a green light because it senses the batteries are full, but instead of being full of power, they are full of crud and need to be replaced again. If the batteries have been properly charged but you still cannot get power, check all your connections to make sure they are tight and that your fuses are not blown.
Oct 12, 2010 | Electric Mobility Health & Beauty
Suspect the charger is shot on a seldom used like new Companion II. The batteries are at 3 volts but the charger red light wont illuminate when plugged in. Green light comes on, but not the red. I did see...
MStrong The charger will not charge batteries that are reading that low Replace the batteries and try the charger again. Remember to always charge before use and never charge longer than 12-16 hours. Get into the habit of charging overnite on scooters used everyday and once a week on seldomly used scooters always sore the scooter fully charged and if storing for a longer time remove the batteries and store fully charged. ope this helps you
Oct 03, 2010 | Golden Technologies Companion II Travel...
My invacare auriga 3 wheel scooter will not work got 2 new batteries but will not power light flashing on charger as if charging but when put key in not even lights comne on
hi,
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
Regards
gewizrepairs.co.uk
Nov 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
Top The Health & Beauty Experts
D. E. Hev
poizniv
poizniv
Level 1 Expert
OHare
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
