Question about Brother Office Equipment & Supplies
How do I get toner cartridge 330 out of my brother printer ?
SOURCE:
  • 12 Answers
SOURCE: Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
Posted on Jul 05, 2008
the kowalski
  • 86 Answers
SOURCE: Brother 5250DN Printer Toner light
Try resetting the toner counter manually;  * Turn off the printer and open the front cover * Press and hold the Go-button down * Turn on the machine while still holding button down, when all three LEDs are lit, release Go-button * Press the Go-button twice, and all three LEDs should be lit again. * Press the Go-button five times (six times if you have the High Yield toner) * Close the front cover and the toner counter should be resetted.
Posted on Jun 02, 2009
  • 133 Answers
SOURCE: resetting toner cartridge on brother hl 2040
Just push down the blue buttom for 1 min.
after you see 4 lights then it's okie now.
Posted on Sep 14, 2009
komguy
  • 2306 Answers
SOURCE: How to take out brother tn 330 toner
You open the front door and pull out the drum and toner assembly and then press the blue lever to release the toner from the drum, place the new toner in the holder and install both together into the machine.
Posted on Nov 19, 2009
  • 13433 Answers
SOURCE: Message on Brother MFC
Open door
press Clear/Back key
press *00
press OK
Do not choose anything for drum replacement. when drum replacement menu comes up, just press the * and then 00, then just press OK.
that should clear the error message, the printer has a toner life counter that needs to be reset.
Posted on Oct 04, 2010
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
Replacement toner cartridge not accepted
I Suggest You To Watch just replaced the toner cartridge and the LCD continues to Brother To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jun 11, 2012 | Brother Toner Cartridge Tn350 for MFC7420...
How do you reset the toner?
Brother toners don't have chips to start a page countdown like most printers. Instead, they use an ocular device that basically "looks" at the toner through a clear hole in the sides and if the beam goes through the cartridge to the other side, it tells you its empty. If you know there is still toner in your cartridge (TN-330 or TN-360 in your case) you can fix it by simply putting a piece of electric tape (or any other non-transparent tape) over the holes. To the printer that will look like a full cartridge. Look on the side of the cartridge; toward the very bottom and center you should see a hole in the plastic. That is what you need to cover. If you want, you can also cover the actual device on the printer, and since its a piece of tape there's no risk of damaging anything, but that is harder to find. Cover it up and give it a go. That should let you print untill the very end of the cartridge, at which time you will see the print quality start to fade.
I hope this helps! Good luck!
Feb 25, 2011 | Brother MFC-7340 All-In-One Laser Printer
How to remove the cartridge on Brother HP1440 printer
Hi seevram,
Follow the procedure below to remove and replace toner cartridges for your Brother HP1440 printer:
1. First, open the Front Cover of the printer.
2. Remove the Toner Cartridge(s) that has run out of toner. Pull the Toner Cartridge out slightly with one hand, then hold the Toner Cartridge with both hands and pull it out of the printer.
3.
After rocking each new Toner Cartridge 3 to 4 times from side to side, remove the tape labeled 'REMOVE' and the orange protective cover from the new Toner Cartridge.
4. Then,
insert the new Toner Cartridge(s) by positioning it in the correct guide(s). Slide it gently into the printer.
Reminder:
  • Do not try to lock or push it in; it should rest loosely in the guide rails.
  • Each color cartridge is individually keyed to prevent improper installation. Match each cartridge color label to the corresponding label on the printer.
5. Finally, close the Front Cover.
Also, I have included here a link where you can download a service manual for your Brother HP1440. Kindly click here.
Hope it helps.
Thank you for using Fixya.
Feb 16, 2011 | Brother HL 1440 Laser Printer
How to change toner cartridge TN330
Hello
Once you have the correct Brother Toner for your printer model, power your printer OFF and open the cartridge box.
Next, you need to open the top cover of the printer. You should do this carefully to prevent damage to the interior or exterior of the printer.
Once the printer top cover is removed, you want to extract the empty Brother Toner cartridge from the printer by pulling upward and away from the machine. You should be able to do this without a great amount of force.
After you've taken the Brother Toner cartridge from the printer, you want to prepare the new cartridge for insertion. To do this, you need to remove it from the plastic bag it is contained in. Next, you need to remove the rip strip from the cartridge. The rip strip is attached to a plastic film strip. Removing the rip strip is important because if you don't your printer will only produce blank sheets. Take care when ripping the strip off, as you may get Brother Toner on your clothes which can stain. If you end up spilling toner on yourself you can wash it off with cold water.
Next, you want to place the new cartridge in the printer the same way the old Brother Toner cartridge came out. There will most likely be arrows on the package to guide you in the placement that will help you make sure you're putting it in correctly. Much like removing the used Brother Toner cartridge, it should slide in with minimal force. If it doesn't slide in easily you should make sure that the Brother Toner cartridge is the correct cartridge for your model printer and then make sure that it is aligned correctly.
Once you have the cartridge in the printer properly, put the printer lid back on.
Now you are going to print a few test pages to make sure that everything is working the way it should. If the printouts look good: You are done. Package the old toner cartridge in the box the new toner came in and recycle it. If the printouts look bad: Sometimes cartridges can be defective. If there were problems with your test pages, you may need to try the process again with another toner cartridge.
Jan 17, 2011 | Brother Office Equipment & Supplies
Brother DCP 330 Paper squizes and jam
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
Dec 22, 2010 | Brother DCP-330C All-In-One InkJet Printer
Toner light is on on Brother HL-2170 Laser Printer and the computer is not recognizing a print task. Can you help me fix this problem? Also, I just replaced toner a couple weeks ago.
Description of Problem 100000013553
I just replaced the toner cartridge and the Toner LED is still on, or the status monitor continues to display the message "Toner Life End". What can I do?
Description of Solution 200000017394
@font-face { font-family: Verdana;}@page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; }P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"}LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"}DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman"}A:link { COLOR: blue; TEXT-DECORATION: underline}SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline}A:visited { COLOR: purple; TEXT-DECORATION: underline}SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline}DIV.Section1 { page: Section1} If the Toner LED is still on, or the status monitor continues to display the message "Toner Life End" after installing a new toner cartridge, verify you are using a genuine Brother toner cartridge.
The yield of the TN starter toner cartridge is approx. 1,000 pages.
The yield of the TN330 toner cartridge is approx. 1,500 pages.
The yield of the TN360 toner cartridge is approx. 2,600 pages.
Approximate cartridge yield is declared in accordance with ISO/IEC 19752(Letter/A4).
Brother strongly recommends that customers use only genuine Brother drum units and/or toner cartridges. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brother limited warranty does not apply to any problem that is caused by the use of third party drum units, toner cartridges or toner.
1. Verify you installed a NEW, out of the box, genuine Brother toner cartridge (TN360/TN330).
If a toner cartridge from another machine was installed (even if there?s still toner left in the used cartridge) or a starter toner cartridge (included with the purchase of a machine) was installed, the Toner LED will stay on and the message "Toner Life End" would continue to appear on the display.
2. Verify the toner cartridge is installed correctly by following the steps listed below:
a. Open the front cover by pulling the tabs on the left and right side of the printer towards you.
b. Lift the drum unit slightly and pull it out. Place the drum unit on a piece of disposable paper or cloth to avoid spilling and scattering the toner.
c. Remove the toner cartridge from the drum by holding down the lock lever (blue tab) on the left side of the drum unit and lift the toner out. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, immediately wash it off with cold water.
d. Gently rock the toner cartridge from side to side five or six times to distribute the toner evenly inside the cartridge.
e. Place the toner cartridge into the drum (be sure it clicks into place).
f. Clean the primary corona wire inside the drum unit by gently sliding the blue tab on the top of the cartridge from right to left several times. Return the blue tab to the home position before reinstalling the drum unit assembly.
g. Reseat the drum unit into the printer pressing it in securely.
h. Close the front cover making sure it latches on both sides.
If the Toner LED is still on or the status monitor continues to display the message "Toner Life End" the printer will need service.
The printer has a one year limited exchange warranty. If the printer is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the printer is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
Jul 21, 2010 | Brother HL-2170W Laser Printer
Put in new toner still says toner needs replacement ? Using original Brother toner?
Brother says a standard toner cartridge will print about 3500 pages ... Things You'll Need: Replacement toner cartridge; Piece of paper ... Turn off the printer and allow it to cool for at least 15 minutes, if you have been using it recently. ... Put the new toner cartridge in the printer same way the old toner ...
www.ehow.com/how_6394835_change-toner-brother-mfc_8220.html
Jul 20, 2010 | Brother MFC-7220 All-In-One Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Open Questions:
18 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
