SOURCE: washer wont spin
if the belt under the washer is intact then the transmission is bad. generally its time for a new washer unless its still under warranty
SOURCE: Kneading Blade for Magic Chef CBM 250-2
I found a compatible belt!!! It's a Dayco # 15260, which you can order from partstore.com!!
SOURCE: Magic Chef 20lbs hd won't agitate
Try these
pls rate my suggestion.......
SOURCE: magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
