Question about Kenmore Washing Machines
5 year old top loader Kenmore leaves black streaks on white wash. Why & how to repair?
Not overloading, using highest water level & warm wash/cold rinse
SOURCE:
  • 209 Answers
SOURCE: front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Posted on Sep 19, 2007
BNewberry
  • 93 Answers
SOURCE: water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Posted on Jan 12, 2009
gdmisp
  • 66 Answers
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Posted on Jan 16, 2009
WRMtech
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
stephanos18
  • 144 Answers
SOURCE: Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Posted on Mar 25, 2009
I have a Kenmore series 600 washer which leaves white residue on laundry. I've tried using less detergent (only use liquid detergent) but it still happens. Using Tide detergent.
There are a lot of causes for that issue. Overloading, too much softener, bad drain pump, dirty drum, hard water are some of the more common ones.
Jan 11, 2017 | Kenmore Washing Machines
Tip
With only two fairly clean adults in the house, I use the front loading Kenmore...
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
on Apr 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hello i m looking for a washing machine for our family we have never used washing machine. we have 7 members in our family which is the right machine for us?
Stay away from a Calyspo, Neptune, Elite. These are problem machines. I would also stay away from any of them that have a digital readout. Water and that type of electronics do not mix. I have a whirlpool top loader that has a dial. It's over 13 years old. I have replaced a pump twice and repaired the lid switch. Simple fix and the cost was small. Most people have trouble with washers due to overloading them. I never overload mine inso it has given me good service.They still make these machines under different names like maytag, roper and kenmore which are owned by whirlpool. Front loaders leak and give problems in a couple of years.
Jan 16, 2011 | Washing Machines
I get brown streak type stains on my clothes regularly. They are about 1 to 3 inches long and orange-brown in color. They are very difficult to remove. I have a 5 year old Kenmore Elite top loading...
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Green whites?
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Small brown spots on whites
Nov 15, 2008 | Maytag PAV2300 Top Load Washer
Front loader washing machine = black streaks on clothing
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Whites going gray improper water level?
I cant say nothing with out a visual check, but gona give you a tip, in the past one client complain the same to me, and was a leaky transmission getting grase in the tube, check that point..good luck
Aug 06, 2006 | Kenmore 43142 Front Load Washer
Washing Machines Logo
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
