Question about The Health & Beauty
Fuse location on the ventura 3 wheel scooter. Batteries are fully charged but, my charger doesn't work. Want to check fuses first before replacing charger
SOURCE:
  • 32 Answers
SOURCE: batteries are charged disconnected and used seperate charger thet had 3/4 charge to start with push start button nothing wheels locked but when charger is plugged in controller lights light up showing
it sounds like dead cel in one of the batteries, try having batteries loaded tested.
Posted on Jul 13, 2009
  • 177 Answers
SOURCE: road knight mini, 3 wheel scooter, light flashes o...
Hi. Does the light flash a few times and then pause, and then repeat the flashing ? Count the flashes, it is a fault code. Do you have the fast/slow switch in slow? It might be a speed control fault. How old are the batteries? Might have a faulty motor. Faulty motor or battery leads and connectors. Go for a ride and then check if any of the plugs and sockets feel hot.
Posted on May 28, 2010
  • 177 Answers
SOURCE: batteries won't charge
Hi. Sounds like there is a faulty connection somewhere between the charger and the batteries. Are the batteries connected correctly. The charger uses the voltage level in the batteries to regulate itself. If there is a faulty connection, then the charge will not operate. Use a multi-meter to check if the batteries are connected correctly. There should be 24 to 26 volts across both batteries.
This fault can also be caused by a faulty charger socket. Check for any signs of melting or heat damage. There might also be a disconnected wire in the plug on the charger itself.Good luck. Neil.
Posted on May 29, 2010
  • 177 Answers
SOURCE: just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
Posted on Jun 05, 2010
  • 313 Answers
SOURCE: i have a 4 wheeled shoprider sunrunner scooter.
Possible one or both batteries have had there day. How old are the batteries. If they are between 1 and 2 years old they will probably need replacing. it would be adviseable to get the batteries tested and have the charger checked as well. When did it have its last service ?
Posted on Aug 01, 2010
Scooter will not charge. New charger, new batteries, new fuse, still will not charge? Can you help?
Get the batteries load tested and the charger output current checked. May be new but they can still fail. Is it the correct charger for the size of batteries?
Is the key turned off on the scooter while charging?
May 25, 2015 | Afikim Breeze S 3-Wheel
How do I recharge the battery tried replaceing the fuses but it will not charge
the charging fuse on these is internal inside the battery box
1 carry out a continuity test in this blade fuse for open circuit
2 while open check battery volts is over 11 volt or scooter will drive=o/k if lower will need batteries replaced.
3.make sure your charger is the correct one for this scooter
as go go chargers conector are wired different .so a standard mobility charger wont charge these,as there will be no 24volt at pins 1 and 3 ,
Jan 15, 2015 | Pride Mobility Products GoGo Elite...
Green light does not come on the power charger
hi, there could be three reason for his .
following the instructions below for a external charger
1. the charger cannot see the battery voltage, this could be because a fues on the scooter has blown. the charger socket is damaged.
2. the Batteries never fully charge because they are damaged.
3. the charger itself has a fault.
I believe that scooter has the charge fuse locate on the tiller column,
Follow the instructions below for a built in charger, if that the case check the fuse on the battery leads,
Otherwise in my experience the batteries cannot be fully charged because they have a fault
Rarely is it the inbuilt charger that is faulty.
http://www.pridemobility.com/pdf/Owners_Manuals/INTL_Scooter/uk/UK_Celebrity_XL_om.pdf
Regards
Please give feedback...
Dec 16, 2012 | Pride Celebrity Xl 4 Wheel Scooter
I am plugging my charger in and it is not charging the batteries
There are 2 charging and battery related fuses on this model that should be checked and if burnt open replaced with the same color and fuse type. One fuse is located under a rubber boot near the charging port. Use needle nose pliers or your finger nails to remove and inspect. The second fuse is hidden under the battery box. Pull up and out to remove the battery box and inspect the fuse in the base underneath. If both of the fuses are OK open the battery box and check all the connections. You will need a long phillips #1 screwdriver to do this. Hope this helps
Aug 05, 2012 | Pride Mobility Products GoGo Elite...
Batteries seem to be low but charger doesn't appear to be working
Easy you just need to replace your Batteries your charger will not charge bad batteries so that's why it seems like that in most cases, now it also could mean you have a bad charger as well.
Aug 25, 2011 | Pride Maxima 3-Wheel 3-Wheel Scooter
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
Sundance will not take a charge. Breaker is good, front 5 amp fuse is good. All connections are good. Batteries are new. Can also drive away while charge plug is in wall socket. I understand there is a...
On the older sidekick(sundancer) there is an ATO fuse in a rubber boot under the pyramid shaped cover to the rear electronics console that runs to the meter on the pyramid. The newer sundancers have no rear fuse at the electronics tray for the charger. You more likely have a bad charger which is causing an inhibit condition. Usually the scooter will drive away with the charger plugged in until the capacitor drains (1 minute). By unplugging the charger you can get the scooter to run. Check the fuse and the meter connections, then replace the charger with the newer Maximizer style charger with the harness adapter kit.
Nov 25, 2010 | Pride Sundancer 3 Wheel Electric Scooter
My invacare auriga 3 wheel scooter will not work got 2 new batteries but will not power light flashing on charger as if charging but when put key in not even lights comne on
hi,
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
Regards
gewizrepairs.co.uk
Nov 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
New batteries, fully charged, still wont work
I will ask but don't take offence, so many people overlook the obvious, have you checked the free wheel lever/s are not set to free wheel (if it is the scooter will be relatively easy to push forward or backward) if set to free wheel then move lever/s to drive position
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Sonic_om.pdf
this is a link for the sonic scooter user guide, not 100% sure that it is the exact one or not but it should show you were to find the free wheel lock on your scooter it is in this guide and I would be surprised if it is not the same as yours. Hope that helps. Mark.
Oct 29, 2008 | Pride Sonic 3 Wheel Portable Scooter
Health & Beauty Logo
20 people viewed this question
Top The Health & Beauty Experts
D. E. Hev
poizniv
poizniv
Level 1 Expert
OHare
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
