Question about Cycling
Can I get assistance in setting clock on Raniaco bike computer
Where can I get a manual for my Raniaco Bike computer?
The link below is said to email you a manual. I have not registered my email address because I receive way too much spam already.
Please let us know if you receive a manual. If possible, upload a copy to FIXYA for others to have.
https://learnhealthylife.com/raniaco-original-wireless-bike-computer-review/
Raniaco Original Wireless Bike Computer Review
Jul 04, 2018 | Cycling
Honda CBF 1000, '07. The time on the clock can't be kept on the memory.
That will happen if there is no power to the clock. I assume the battery is not flat as you can start it. My clock is always on, even without the ignition on and if I disconnect the battery it restarts at 1:00 am. I would check to see if there is power to the clock with no ignition and the wire is not broken in the loom somewhere. I say this because power is obviously getting through when switched on. You will need a wiring diagram for your bike. It is possible it may be connected via an "auxilliary circuit".
Jul 20, 2015 | Motorcycles
My Computer system clock (time) is in a loop, between 12:00hrs and 14:00hrs (Date will not change). I have tried to change the settings in BIOS and also restored the system to a date before the problem...
Hi mutumbac. Please check the battery on your computer's motherboard. All motherboards have a small (clock-type) battery that powers the internal clock even when the computer is turned off. These batteries are good for about 2 years, and after that they should be replaced or else the computer will reset the date and time every time it boots up.
Mar 04, 2011 | HP L1706 17" LCD Monitor
Hi, I've got a 2002 Honda f4i. Basically I have 2 problems with the bike 1. It's running very rough and rich. On cold start it will idol at 3-4000rmp which seems extremely high. Putting it into gear...
for the rich problem, is it standard with genuine exhaust and new air filter?
The random stopping is probably a loose wire(clock reset), check the plug behind the ignition switch, and make sure the kill button is good
Feb 04, 2011 | 2002 Honda CBR 600 F(4)i
My wall oven will not work. The clock is flashing '0:00 auto', I don't have a manual but the grill works???? Also tried pushing the buttons to set the clock and they don't do anything either???? Is this...
The clock will generally only be linked to the main oven. Can you comment on this post with the make and model and I may be able to assist with setting the clock, If the make is a siemens (as this is the section that you have posted the question in), follow the link below and download the manual to assist with the setting of the clock. All the best.
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html open link and then click where indicated to open manual search, then input model number (Enr number).
Sep 04, 2010 | Ovens
Need to set the clock on the bike but don't know how
Turn the radio off. (Power button on left side) Then you will see the clock time and the word set in the lower right corner. Push the button next to the word set and now you can adjust the clock time,
Aug 20, 2010 | 2008 Harley Davidson FLHX Street Glide
Starting problem, clocks light up engin turns softly. not starting. please assist. contact pieterserenier@yahoo.com please if anyone can assist, its a friends bike.
make sure that your battery is fully charged to have enough cranking juice. It happened to my VFR as well, headlights & clock worked but not enough juice to crank. I had this problem with my OEM honda battery, and eventually replaced with aftermarket battery with higher CCA (Cold Cranking Amps). A good thing esp if you live in cold countries
Aug 17, 2010 | 1994 kawasaki ZXR 400
I have a sigma 1606l computor what is the wheel size setting. I have 650x23
you can measure your wheel by placing your bike on a flat surface with the valve stem on the wheel in the bottom most position or 6 o clock position. mark the floor where the valve stem is. now roll the bike forward so that the wheels gets one full revolution and the valve stem comes back to the 6 o clock position and mark the floor at the valve stem. now get a tape measure and measure the distance between your two marks. Convert this measurement to usually centimeters. that will be the number that put into your computer.
Rick
Bicycle Parts and Accessories
Jul 10, 2009 | Sigma Bc 906 Computer
Setting the clock on a 2006 Yamaha Roadliner
the clock is set by holding the button down on the clutch side of the handlebars until your display blinks. The you use the front brake side to adjust the time.
Apr 22, 2009 | 2006 Yamaha Roadliner
Bell f20
here are the wheel value for a Bell F20
Road Bike
20" 1596
22 1759
24 1916
26 2073
27 2124
Montain Bike
24" 1888
26 2045
27 2155
28 2237
I hope this helps set your F20 computer.
Sep 11, 2008 | Sport & Outdoor - Others
Cycling Logo
64 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
