Question about Garden
On a 951D Ransomes wide mower model #946900 - do you know where the hydrolic filter is located. when I go up a hill or in heavy long grass the power slows way down.
SOURCE:
  • 15 Answers
SOURCE: My Troy-Bilt 21'' 3-in-1 self-propelled mower will not start
Next time keep the carburetor up...tipping it down will allow oil to go where it's not supposed to. For now drain out the remaining oil, replace the air cleaner and remove the spark plug. When the plug is out pull the engine over a few times. It's possible that there is oil in the cylinder and this will help clear it out. Replace with a new plug and try. If this doesn't work, repost.
Posted on Apr 23, 2009
  • 60 Answers
SOURCE: My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Posted on Jun 24, 2009
  • 89 Answers
SOURCE: ride on mower drive problem
sounds like a belt to me not tight enough against the pullys
Posted on Nov 09, 2009
  • 634 Answers
SOURCE: engine slows down with blades are engaged?
sounds like the blade spindles are binding, many have Zerk fittings to grease them. with belt disengaged try turning the pulleys they should turn easily and have no wobble in them. if either is wrong replace spindle and best to change in sets. this is the most common issue.
Posted on Apr 23, 2010
  • 63 Answers
SOURCE: I have a new Poulan Pro Self-Propelled Lawn Mower
Yes
Posted on Jul 24, 2010
WON'T THROW GRASS
Is the belt put on right. If not the blades might turn backwards. Check and see if the blades are turning clock wise. They should be.
Aug 27, 2014 | John Deere Garden
John deere x475 mower will not engage after cutting heavy grass
It is probably full of grass in the mower deck. Clean it out and try again.
Sep 25, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro 24038 blade speed governor not working
Not enough torque. Only use 1/2 width of deck on tall grass, go real slow, Ensure side discharge is open! Ensure blade is sharp. Replace spark plug once a year and clean replace air filter. check oil level 30woil.
Aug 10, 2012 | Toro Power Lawn Mower
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Jun 05, 2012 | Craftsman Garden
When first start my husqvarna yth 150 runs fine goes up hills plenty of power after running for while starts loosing power wont go up hills will stll move on flat surface
Hi, it sounds like the hydrostatic drive is getting too hot. Remove the battery and battery cradle and clean all grass and debris from around the hydrostatic drive and cooling fins. Also check the fan wheel on the hydro is not damaged. Regards Phil.
Apr 28, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Poulan pro, right out ofr the box model pr625n21rh3 serial 012010m 004039. the problem is it won't cut the full width of the deck , have to overlap 3" to get full width cut????
This is a 21" mower, meaning the blade is 21" long (maybe only 20.5") and it will cut a 21" wide path of grass. Measure the width of the path that it cuts in the grass. If it is less than 21", then the mower has the wrong (too short) blade on it. It may just have a configuration of deck and wheels that make it look like it's not cutting as wide as it should.
Jul 28, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Craftsman DYT 4000 riding mower: Last year I notice the mower has lost some power. Going up hill and blowing the grass back to the bag catchers. I installed a new carburetor, magneto, fuel filter, higher...
your valves might be sticking due to old gas when you had some or the little rod clutch rod to the carb is disconnected this is just to choke it before it dies out.
I sugest that you clean out the carb out with carb cleaner and also clean the valves.
Mar 29, 2010 | Water Heaters
Garden Logo
20 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
