SOURCE: jensen vm9411 no sound
Check to make sure your vehicle does not have a factory amplifier. If you used a fit kit with wiring harness. try looking at how many wires were used in the factory unit compared to haw many you are using now. see if there are extra wires in the vehicle. If there is extra wires it is a pretty good clue the vehicle has an amplifier and will have to be rewired.
SOURCE: my volume sounds muted on my 36" toshiba tv, nothing is working
Good day.
Please check on the speakers of your unit. They may be busted.
chris
SOURCE: No volume
Have you checked to make sure that your speakers are turned on? Most rear projection televisions have both a physical switch and an interal menu option to turn on and off the built in speakers. The physical switch usually is located in the back near the inputs and outputs. It could have accidentally switched off. Under the menu options it may have been accidentally turned off as well.
SOURCE: My picture is perfect but I lost volume how do I get volume back
You may have turned the tv's speakers off. check your menu to see if thats the case.
