Question about Garden
Need help with PTO lever not staying in gear to operate PTO
5 Suggested Answers
SOURCE:
  • 22 Answers
SOURCE: Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Posted on Jun 16, 2009
wireguy212
  • 1627 Answers
SOURCE: PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Posted on Oct 21, 2009
Adrian762
  • 425 Answers
SOURCE: When I shift my 02 GSXR 600 the gear shift lever gets stuck
Get yourself a repair manual and find out what it says, but I think you are correct, the return spring is either broken or it has slipped. Try this site for a freebie manual:
http://www.carlsalter.com/motorcycle-manuals.asp
Posted on Jan 28, 2010
  • 9 Answers
SOURCE: My Allis Chalmers 6080 PTO will not shut off with the lever. Even though I pull the lever to stop PTO, it stays engaged. Any answer to this issue?
The lever is maybe not engageing the electrical switch so if it worked good in the past something has worn or come loose.Find the point where the lever engages the switch and there are usually 2 wires running to the pto.Also one or more wires might be off the pto.Go from one thing the lever does to the next step and it might be a bad switch if the lever is working the switch and it still does not turn off.Hope this helps
Posted on Nov 05, 2012
Massey ferguson 135 pto keeps throwing out of gear drives but pto wont stay in gear why
possible that the teeth of the pto dog are worn to a taper and not fully engaged
the lever for the engagement is moving the full travel to engage
the bearings on the pto shaft are failing and allowing misalignment of the shaft thereby walking the dog out of engagement
Jan 05, 2017 | Toys
Craftsman zero turn 26 hp kohler engine new pto electric clutch does not work
Sad to say it may have never been a bad pto clutch but probably safety switch problem. The running tractor wants you in the seat, brake off, levers over your lap and not backing up for the PTO to stay engaged . There is two push button switches on each lever that lay over your lap ,one on the parking brake,one under the seat. All of these switch wires meet at the PTO switch and all have to agree they are in the position they need to be in to allow electricity to come down the wire to the PTO Clutch.
Dec 22, 2016 | Craftsman Garden
Shift fork for a 2675 massey ferguson
check that you have the correct lever in position
there is a lever that separates the drive from the pto operation so that you can run the pto with out the gear box
Aug 03, 2016 | Toys
Pops out of 4wd and pto not working and dif. lock not working
PDF]PTO Popping Out of Gear, How to Fix - N Tractor Club
www.ntractorclub.com/howtos/pdfs/PTO-Popping-Out-of-Gear.pdf
PTO Popping Out of Gear, How to Fix ... If your PTO shift lever does not stay engaged, the problem is probably not in the PTO transmission, but rather is due to ...Missing: 4wd
Oct 20, 2015 | Cars & Trucks
Any adjustment for hino dutro tipper pto.
When engaging the pto it is important that you have the clutch disengaged so that the pto gear is not spinning in the box.before it engages.
The pto gear runs off the counter shaft of the gear box and is spinning all the time the engine is running
when engaging the pto ,you are physically engaging a gear ( like selecting 1st gear) so you have to stop the counter shaft spinning so that the pto gear will engage with slashing
Jun 14, 2015 | Garden
Ford 5000 pto
i believe the lever is on the left side that operates the pto. on some models it will have a plate stating its the pto, you'll have to start the tractor, and engage the clutch, then engage the pto, and release the clutch. Others you simply engage the pto once you've started the tractor
Jul 17, 2014 | Garden
Nov 05, 2012 | RTO Allis Chalmers Tractor Pto Shaft...
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tines wont turn /disengaging type grinding noise
its possibly the gears inside the box they are spider gears & wearout on those they are great machines but the gear drives are weak most of the time or the belt could be slipping
Jun 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
