Question about Samsung Tablets & eReaders
My samsung J tablet does not respond to usb stick . Stick light is on
4 Suggested Answers
SOURCE:
ashishd19
  • 35 Answers
SOURCE: Booting from a USB Stick
Here you go:
Download the Ubuntu Live ISO (if you dont have it already) and burn it to CD
Restart your computer (booting from the Ubuntu Live CD)
Insert a 1GB or larger USB flash drive
Open a terminal window and type sudo su
Now type fdisk -l to list available drives/partitions (note which device is your flash drive Example: /dev/sdb). Throughout this tutorial, replace all instances of x with your flash drive letter. For example, if your flash drive is sdb, replace x with b.
Type umount /dev/sdx1
Type fdisk /dev/sdx
type p to show the existing partition and d to delete it
type p again to show any remaining partitions (if partitions exist, repeat the previous step)
type n to make a new partition
type p for primary partition
type 1 to make this the first partition
hit enter to use the default 1st cylinder
type +750M to set the partition size
type a to make this partition active
type 1 to select partition 1
type t to change the partition filesystem
type 6 to select the fat16 file system
type n to make another new partition
type 2 to make this the second partition
hit enter to use the default cylinder
hit enter again to use the default last cylinder
type w to write the new partition table
Type umount /dev/sdx1 to unmount the partition
Type mkfs.vfat -F 16 -n usb /dev/sdx1 to format the first partition
"Alternately you can try mkfs.vfat -F 32 -n usb /dev/sdx1 (doesn't always work)"
Type umount /dev/sdx2 to ensure the partition is unmounted
Type mkfs.ext2 -b 4096 -L casper-rw /dev/sdx2 to format the second partition
Remove and Re-insert your flash drive
Back at the terminal, type sudo apt-get install syslinux mtools
Type syslinux -sf /dev/sdx1
Restart your computer, remove the CD and boot back into Windows
Using Windows to prepare and move the files to the USB Stick:
Create a folder named USB on your computer
Download UBconvert.zip using this link - http://www.pendrivelinux.com/downloads/UBconvert.zip
Now, extract the files to the USB folder
Move the Ubuntu  ISO downloaded earlier to the USB folder
Click fixu.bat from the USB folder (follow on screen instructions)
Move all files from the ubuntu directory to your memory stick
Reboot your computer and set your system BIOS to boot from USB-HDD or USB-ZIP. Also set the "Hard Disk Boot Priority" if necessary.
You should now be booting into Ubuntu Linux from your USB drive!
Posted on Dec 28, 2008
Nicolas_y
  • 243 Answers
SOURCE: Hi i have a samsung NP-Q1 tablet pc.
Yeah! You can. As far as I know, third party software Windows Login Recovery is used to reset forgotten windows password and the windows password reset file can be stored in a USB flash drive.
Posted on Jun 03, 2010
  • 22 Answers
SOURCE: My Archos 101 tablet's full sized USB port doesn't
This seems to be a widespread problem with the Archos 101 tablet. There have been 2 firmware updates since the problem was first reported, and neither seems to have fixed the issue for anybody, which strongly suggests that it is a hardware issue, in which case you'll need to do an RMA. I recommend contacting the retailer you purchased through so you can get a replacement unit or a refund.
Posted on Feb 28, 2011
How to send video from android tablet to phillips gogear4.0
I send my videos firstly to my computer via the 'share' and email link. Once there I file them.
To put them on a memory stick etc. I plug the stick into the USB port.
I find the video. Right click and 'send to' and click on the appropriate item
Oct 06, 2017 | Tablets & eReaders
How do i transfer music off a flash drive onto my RCA 10.1 Android tablet
tablets use the charge port as a usb extension
try using a usb connector from the usb stick plugged into the charge port
Sep 17, 2016 | Tablets & eReaders
Transferring from Nexus to computer
Hi I use a USB memory stick with female lead & mini USB male cable just download onto USB stick & plug it in you're computer good luck
Feb 28, 2016 | Google Nexus 7
How do I transfer e-books from USB-stick to Lenovo tablet S6000
plug usb thing to levon tablet then open your files you will see it there
Nov 26, 2013 | Lenovo Tablets & eReaders
Cannot get wifi
Turn router off at wall switch, wait 5 minutes then restart.
Dec 19, 2017 | Tablets & eReaders
How to transfer photos from my pc to a archos80 g9 turbo tablet
Some pc control panels hv porgrams to use to transfer across otherwise u could put them into a "Google.com" (or cloud) account and then pull them down from there. If u hv a USB connection on the tablet then use that by downloading to the data/dongle stick, and upload off that.
Aug 01, 2012 | Archos Tablets & eReaders
How do i transfer photos from a usb stick to asus transformer
You need to get the Asus Transformer Keyboard Dock. It has 2 USB port built in.
Buy it here on amazon.
Otherwise you need to a microSD card.
Aug 21, 2011 | ASUS Eee Pad Transformer TF101A1 Tablet...
My Archos 101 tablet's full sized USB port doesn't acknowledge my stick drives. It did but now doesn't. I plugged a hub in and it lights up but the tablet still does not recognize the stick drive.
Feb 22, 2011 | Archos 101 Tablet PC
Hi i have a samsung NP-Q1 tablet pc. I have forgotten the windows password and cannot get in. I do not have a external Dvd drive and cannot use any cd's. Is there a way i can use a standard usb stick and...
Feb 24, 2010 | Samsung Q1 Ultra Tablet PC
Tablets & eReaders Logo
29 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
