SOURCE: Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
SOURCE: Connecting new 5 wire low volt to an old 4 wire L/Volt
You will have to change out the thermostat wire if you do not have another wire in the sheath you can use.
You must have 2 wires for 24 volts hot and neutral. Usually red and blue.
Yellow for the compressor contactor.
Orange for the reversing valve.
White for the indoor heat coil relay.To bring on indoor coil when in defrost mode.
SOURCE: I have a Samsung ht-p1200
You could try rigging headphones to the speaker output if you don't mind cutting some wires and spending a couple bucks on a headphone jack thing.
SOURCE: Digital In on Samsung HT-Z310 no sound
Optical into your XBOX 360? If there is a connector that you are using to convert it, I was start by replacing that.
