Question about Maytag Washing Machines
I've a Maytag Maxima mhw6000xw1 with E01 F09 error. I have cleaned the trap and all hoses. I'm still getting the slow drain error. The pump appears to work on power down, is it the pressure switch?
How would I know if it was the pressure switch or the pump? (or for that matter the CCU)
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: I have a Whirlpool DUET that continually gets F02
"F02" is a Long Drain error (as you well know by now). The error code is generated when the drain time exceeds 8 minutes. If the pump motor or impeller is damaged and it is not pumping at the correct volume, the error code will continue until the pump is replaced.
I applaud your effrots. You isolated the source and did all the necessary steps required to clear this error code, but if you perform all these preliminary measures and still have problems, the rule of thumb is to replace the pump.
The "SUDS" error can occur in conjunction with the "F02" error. If the pump is not functioning properly and air is detected in the drainage system, you will get the SUDS error as well.
"F09" is an overflow condition error code which has many causes, inlcuding the drain pump. Everything seems to point to the drain pump in this one. Replace it and your problems may go away.
A replacement can be purchased at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever part source you like, but I have found these sites to be the most reliable and offer competitive pricing.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Posted on Sep 02, 2009
Testimonial: "Fantastic, you read my description, confirmed what I've already done, and told me what to replace and where to get it. You went above and beyond ...!"
  • 1314 Answers
SOURCE: Washer will not leave the drain cycle
ok let me pull up the servic manuel and ill get back to you ok we are all trying to help but takes time ok
Posted on Jan 15, 2008
MNfisherman
  • 11896 Answers
SOURCE: GHW9150PW0 Whirlpool Duet washer will not spin F02 and Sud
There is a sensor that relays information back to control board. If you have new pump, pressure switch and latch, the sensor is most likely faulty
Posted on Jun 30, 2009
  • 170 Answers
SOURCE: SUD Code appears on Whirlpool
sud means over suds are you useing he soap maybe too much.......
Posted on Mar 24, 2011
jdhaskett
SOURCE: I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Posted on Dec 10, 2012
My F09 and my E01 codes keep coming on in mid cycle and shutting down the cycle
F09/E01 are related codes.
LONG DRAIN: If the drain time exceeds 8 minutes without reaching reset level in pressure sensor, the valves are turned off and the drain pump will stop running. NOTE: Suds can cause delays in draining. Washer drains for 4 minutes, pauses 5 minutes, then tries again for 4 additional minutes of draining. F9E1 will display if washer does not drain. (Normal drain takes less than 2 minutes)
Possible Causes:
Verify that the drain hose is not blocked or kinked.
Make sure drain hose is not sealed into drain pipe.
Make sure the drain hose height does not exceed 96" (2.4 m).
Check/clean drain pump filter of foreign objects.
Check connections from tub to air trap, air trap to pressure hose, and pressure hose to pressure sensor.
See TEST #8 (Drain Pump) on page 19. Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?
Oct 03, 2016 | Whirlpool Washing Machines
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
I have a front load whirlpool washer purchased in 2012 that is displaying error code E01 F09. I cleaned out the trap for the drain pump, took the suction line off from the bottom of the drain and ensured...
hi i would just try a new pump anyway as they are cheap anough if you put a universal one on,i paid about £20 for the one i put on at work,im just a kitchen porter come what ever needs fixing ,it might be a compasitor that puts the motor into top speed but you need to be smarter then i am to test and discharge them,i take it all the sprung legs are in there wright position as they do come detatched if the load was not even
Mar 04, 2015 | Whirlpool Duet GHW9150P Front Load Washer
What does error message E01 and F09 mean?
Long drain something restricting water flow in drain cycle
Jan 10, 2015 | Maytag Washing Machines
What are the error code for F09 and E02. for maxima maytag
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
Error code f09 e01
Did you clean the tube that goes from the tub to the drain filter then the drain pump it is behind the front panel also make sure there is nothing in the drain pump stopping the impeller from turning.
Jan 29, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
Suds and F02 Error codes.
You did all the right thing, now it could be the control panel
Mar 29, 2013 | Maytag EPIC MFW9600S
HE3t Washer Problem -
Clean out the drain pump, if this doesn't resolve it then replace the drain pump,this will resolve you issue.f09 means slow drain or no drain.
Oct 30, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
