SOURCE: Whirlpool dishwasher Fault codes
Fault code related to Flow meter. Cleaned the connections and reconnected.It worked fine for 2 weeks and failed again.Replaced the water chamber which contains the flow meter and the issue is resolved. The water chamber cost me 87euro including postage from Quinnspares in Co.Derry Ireland.
SOURCE: Merits DL 52 i electric wheel chair, all leds flash 3 times.
The number of lights that are blinking indicate what the problem is.
Visit this site to locate the type on controller on your power chair and
you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer
for service. If your insurance purchased they power chair for you, they
may also cover the cost of repairs.
SOURCE: check engine light flashes 4-3-7-1 what will be the code number
I would guess 2 codes--43 and 71. 43 says starter signal not reaching ECM. Are you push starting the truck? If not, might be a bad wire from the ignition switch to the computer.
71 is low EGR gas temp. Could be the sensor signal is not reaching the computer but more likely the EGR valve is not opening. May be stuck/clogged, has torn diaphragm, or is not getting vacuum. I believe the vacuum is controlled by a thermal valve. Check to see that the thermal valve is getting vacuum from the intake manifold and opening to deliver vacuum to the EGR valve when the engine reaches operating temp.
SOURCE: panasonic th-42px20 fault codes flashes 7 times
Check all in voltages to power supply at the moment of turn on--check outputs at same time---is one missing or goes down instantlly?
SOURCE: I need to find the anti tip wheels for a Merits pioneer 3 mobility scooter
Hi MONSTER SCOOTER PARTS SELL 40 mm MERITS ANTI TIP wheels .$9-95 each...cheers
