Hello John, indicate that LG TV model, you are commenting the problem, to find the best possible solution
From what you mention, it may be a failure in the LCD panel lighting
I wait your answer
Greetings Franco Dosil
Hola John, indica de que modelo de TV LG, estas comentando el problema, para poder encontrar la mejor soluci?n posible
Por lo que comentas, puede ser una falla en la iluminaci?n del panel LCD
Espero Tu respuesta
Saludos Franco Dosil
Testimonial: "Hi the model number is 47LW5600"
Hello again John, well the model of your TV LG 47LW5600, so I could find out, there may be the problem in the plate of the power supply
I send you the link of a video referring to the failure of your LG
I hope you can solve the problem, but I suggest you take the TV to a specialized technical service
Hola Nuevamente John, bien el modelo de tu TV LG 47LW5600, por lo que pude averiguar, puede estar el problema en la placa de la fuente de alimentacion
te mando el link de un video referente a la falla de tu LG
Espero puedas resolver el problema, sino te sugiero que lleves el TV a un servicio tecnico especializado
Thank you. I will take a look at the video now. Unfortunately the quotes the repair service give me are higher than buying a new tv
Well John, I'm sorry that you can not repair your TV, try another technical service or if you buy another, do not discard the LG TV and try to repair it, buy the license plate and change it
Lost for lost, it's worth it
I hope you keep well
Bien John, lamento que no puedas reparar tu televisor, intenta en otro servicio t?cnico o si te compras otro, no deseches al TV LG e intenta hacerle la reparaci?n vos, compra la placa de fuente y c?mbiala
Perdido por perdido, vale la pena
Espero que sigas bien
SOURCE: xbox 360 solid green light in the middle
hey gandylt, i had the exact same problem happen to me acouple days ago. i bought an additional working xbox 360, and i decided to up grade the cooling. anyway let get to the point.
There were three things that i did that solved the problem.
1.) I removed all heatsinks to find that i did an crappy job on applying the artic silver, it was everywhere. so one thing u want to do is make SURE THERE IS NO THERMAL compound on the motherboard PERIOD! the thermal compund can act like conductors, therefore if its all around the motherboard it can actually BRIDGE two different flow routes on the motherboard which isnt good at all. So Clean the mother board with 90%+ Alcohol.
2.) Second i reapplied the artic silver 5 in an very thin layer! its important not to have too much.
3.) Third. i didnt tight the heatsink bolts so tight like i did the First time. tight them but dont tight them too much.
Those were the exact 3 thing i did to get my 360 recovered from the following error. good luck guys!
SOURCE: Black screen and no sound on TV
what is the brand, model? try to be specific if you want be helped!!!
SOURCE: Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
SOURCE: Mitsubishi XD510U Status light is blinking
Page 30: replace the lamp (Page 25)
Spare lamp for XD510U/XD510U-G/SD510U: VLT-XD510LP
http://www.retrevo.com/support/Mitsubishi-XD510U-Projectors-manual/id/15978dj994/t/2/
We have a lg 55lv5500, black,v no picture no sound, we have the TV apart but not sure what to do next?? Can you help
