Hello Jaunius, indicate if the remote control you are commenting on, is an original replacement or if it is a universal remote control, indicates the type, brand and model, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Jaunius, indica si el control remoto del que estas comentando, es reemplazo original o si es un control remoto universal, indica el tipo, marca y modelo, para poder encontrar la mejor solucion posible
Espero tu respuesta
Saludos Franco Dosil
https://www.download.p4c.philips.com/files/h/hts3450_37/hts3450_37_dfu_aen.pdf
Correction - my device is HTS3540 and it is the original replacement remote
Hello again Jaunius, well your Philips is an HTS3540 model, if you bought an original remote control, as a replacement for the one you had, you do not have to configure anything, to be able to operate your Philips HTS3540 Home Theater, you have to walk directly, as you did with the first original remote control
If the new remote control does not respond, it is very possible that you have a problem with the device receiving the remote control of the Home Theater equipment
Check that there is nothing stuck on the front of the
Home Theater equipment, which may be blocking the remote control receiver
I hope you can solve the problem
Hola nuevamente Jaunius, bien tu Philips es un modelo HTS3540, si has comprado un control remoto original, como reemplazo del que tenias, no tienes que configurar nada, para poder manejar tu Home Theater Philips HTS3540, tiene que andar directamente, como hac?as con el primer control remoto original
Si no te responde el control remoto nuevo, es muy posible que tengas un problema en el dispositivo receptor del control remoto del equipo Home Theater
Controla que no haya nada pegado en el frente del
equipo Home Theater, que pueda estar tapando al receptor de control remoto
Espero puedas solucionar el problema
Saludos Franco Dosilhttps://www.download.p4c.philips.com/fil...
SOURCE: Pairing a Motorola H850 to A Lg5300 cell
hi
turn on your hands free device. find "connectivity" in settings on your phone. then "bluetooth link". then "hands-free". turn on bluetooth. look for devices. pair from there.
that should do it.
dave.
SOURCE: Paired with old phone, can't pair with new phone.
have ya phone ready to almost pair. Then on the 850 ear piece press the call button until lit and then open boom up and press the phone pairing ok button and the 850 should work. waaala!
See how easy that was.
SOURCE: pressed the wrong button on the remote
There is a button on the remote labeled "tune" when you push this it will display direct tune on the receiver. You can then enter the channel. It should stay in that mode unless you push the band button again. Hope this helps
SOURCE: Harmony 890 Pro will not pair with Xbox360
The RF signal is on the XBOX is used for the controllers only.
When using the Harmony 890 with a 360, you will have to use it as an IR (infrared) device. That is the only way to use a remote with the 360. If you have an extra port on your RF extender, you can place the end on the remote senor on the 360 (located under the eject button).
I set these remotes up weekly, it is a product I recommend to people all the time!
But again, the only way to setup a remote with the 360, is to use the IR port as a standard IR remote. Since the controllers run off RF, the learn function will not work, unless you already have 360 remote control to use to do the learn function.
Hope that offers some insight. This information can also be verifies at Microsoft XBOX 360's FAQ page.
Testimonial: "Yes! This was VERY helpful as I did not know the Xbox360 accepted IR commands. However, after configuring my remote, I'm still unable to pair. ideas?"
SOURCE: hi my philips hometheater HTS3450 subwoofer power
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
