Clear weather alert after level654 1 pet no key
Is the Best Pet Folding Play Pen weather resistant? Will the rain ruin it?
Yes, the Best Pet folding play pen is weather resistant and you can use it indoors or outdoors but if the weather was really stormy or heavy rain, i would bring mine indoors just to help it last longer.
Aug 16, 2012 | Pets - Others
The alert is to loud, how can I turn down the volume for the alert?
Press the WEATHER/SNOOZE button to turn on the weather radio. Then press the "UP" or
"DOWN" volume button to select desired listening level. (Note: Turning the volume all the way
down [where no bars show] puts the radio into silent mode.)
Hope that helps resolve the issue.
Regards
Anand
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
Why does my weather radio just beep, no voice, no lights? I have put in all codes for my county
Good morning, afternoon, evening or night; whatever time of day you are viewing this. You want to know why your weather radio just beeps and no voice or lights function properly. This has nothing to do with the codes you put in for your county. This has to do was the type of alert setting that is programmed into the radio. The alert setting that you have programmed into the radio is probably that TONE alert type. When this is selected, the alert will sound for 5 minutes or until any button is pressed except for the Weather/Snooze button. If you want your alert type settings changed, press MENU and use the up and down directional buttons until "ALT TYPE" is displayed on the screen. Use those same directional buttons to choose the alert type of your choice. If you choose DISPLAY, a text alert will scroll on your screen and no audio alert type will be sounded. If VOICE is selected, an alert will be sounded 8 seconds and you will hear the voice of the weather broadcaster for 5 minutes. These are the only other alert types you can choose other than TONE. Once you have chosen your alert type, press SELECT and and press MENU to exit. Remember that the NWS will only alert you if the storm meets their serve weather criteria (meaning the storm has to be able to cause a certain amount of damage or life threatening to "Wake someone up in the middle of the night"). With this radio functioning properly, it can really help you out in the long run by alerting you with the lastest information of what's going on in your area. Thank you for choosing FixYa as your one-stop solution spot for your problems and thank you for reading my solution.I hope this is the solution to your problem and it clears up any confusion you may have. Have a good morning, afternoon, evening or night; whatever time of day you're reading this.
Apr 04, 2011 | Midland Weather/Hazard Radio with SAME...
How do i change my vhs from US to INT AS I CANT FIND MANUAL. IT THE SOLAR MODEL?
From page 4 of your owner's manual:
WX/ALERT/UIC - Press this key to listen to active NOAAWeather channels.
Press and hold this key for 2 seconds to place the radio into the Weather
Alert mode. Press both HI/LO/SCAN/UIC and WX/ALERT/UIC at the same
time to change channel modes from USA to INTERNATIONAL to
CANADIAN.
Aug 14, 2010 | Uniden Solara Vhf Dsc Fixed Mount Radio
Need to make sure programmed
Program the Midland 74-109 Weather Radio
a) Turn unit on. Extend the antenna. Adjust volume up slowly; Do you hear anything? If not, try replacing the 9 volt battery with a fresh one, in the accessible battery compartment underneath the unit. Repeat above steps.
b) If no sound is heard, turn unit over and look for "WEATHER" slide switch on bottom. With unit on & volume adjusted to comfortable hearing level, slowly slide switch down (or up) through various frequencies [1)162.550, 2) 162.400, 3) 162.475, 4) 162.425, 5) 162.450, 6) 162.500, 7) 162.525] until voice transmissions are heard. This should be the closest National Weather Service (NWS) broadcast for your area. Check the NWS website at http://www.nws.noaa.gov/nwr/nwrbro.htm for your state, click on the state name, and look for the site name or site location nearest you. The frequency for that site should be the strongest, and appropriate for your area.
c) You can set the alert tone, for special weather alert broadcasts, on the bottom of the unit on the slide switch marked "ALERT". Set the switch to the desired type of alert: 1) LED [LED on top of unit (marked ALERT) lights up when alert is broadcast-no siren tone/alarm is heard] 2) LED & ALARM [LED lights up and alarm/ siren tone is heard] 3) VOICE [LED on top of unit lights up and voice broadcast is heard, only; no siren tone/alarm is heard].
d) Be sure to press the "ALERT" button on top of the unit and leave the volume at a comfortable listening level to hear weather alerts for your area (Alert LED on top of unit lights up to show Alert function is active). You can test the present volume level by pressing the "TEST" button. Be sure to press the "ALERT" button again after listening to the volume level to re-set the Alert function. You can listen to weather broadcasts anytime, by pressing the "WEATHER" button. After listening, be sure to re-press the "ALERT" button to reset the Alert function.
e) 9 volt battery life should last about 6 to 7 months, depending on how much unit is used an number of alerts received. Replace battery every 6 months, or when you replace your smoke alarm battery, or at beginning and end of daylight savings time. A 12 volt AC adapter to replace the battery, can be used. One should have been supplied with unit. If not, a replacement can be found at Radio Shack.
f) This should complete your Midland Weather Alert Radio Model 74-109 programming.
Apr 09, 2009 | Midland 74-109 Weather Radio
Automatic Weather Alert
Weather Radio WR.100 was defective. Returned unit to retailor for replacement. Problem solved.
No further action required.
Krehgil
Sep 12, 2008 | Midland WR-100 Weather/RDS Radio
Vector Stormtracker Elite
Click on the mute button while WEATHER is selected on the dial. This should MUTE audio and ALERT will appear on LED. Then you will only hear ALERTS.
Mar 08, 2008 | Audio Players & Recorders
162.550 NOAA weather frequency
If your still having the problem, it could be that the transmitter for that freq lost some of it's power, so your scanner cannot pick up a clear signal. If everything else is working ok, that's my guess. Hope this helps,,, Mechanic
Nov 15, 2007 | Radio Shack Pro-94 Scanner
 Grubhead
Grubhead
Marvin
Marvin
