WHILE SWITCH ON THE MACHINE H2 ERROR CODE COMING, HOW TO CLEAR THIS PROBLEM.
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
SOURCE: Daewoo DWD G1243S washing machine
When you hear that macinhe is beeping and giving 1E code, turn it off and make sure that water feeder is turned on and that it can feed water into the machine, turn it back on and start your program, it should be fine :) .... Good Luck....
SOURCE: Daewoo DWD-G20D1 Error OE machine wont
'...won't drain of water...'
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: I have a Daewoo DWD FD1233. It's brand new &
Daewoo e8 - engine error! or Bad soldering.
Remove the control panel (the one in which many connections). Remove the rear rubber compound around contacts blue relay.
Resolder them. And it will be all ok!
Or - remove the entire back of the compound and look for where the bad soldering (cold soldering ). You can see it - blackened or exfoliated. Just solder all.
