Https://www.gme.net.au/media/2444484/tx3350_im_web.pdf Down load user manual from above link and read page 12.
SOURCE: Radio Shack TRC-502 cb radio
Here is the owners manual I'l see if I can get my hands on a internal schematic
http://support.radioshack.com/support_electronics/doc62/62220.pdf
SOURCE: I would like to find the correct 2 digit channel Display
in most cases one of the 16 pins on the channel display has a bad contact, I have the displays in stock and ready to install if you need the work done.
Thanks,
Dodgem250.com
SOURCE: I'm using the pre set cb radio band to scan cb,
press the manual button until you get to channels you locked out, then press Lockout and they will unlock.
Thanks,
Dodgem250.com
SOURCE: Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
SOURCE: i have a 29ltd classic...no
Sounds like the mixer crystal has gone bad, or the VCO is out of whack, and the radio needs to be aligned.
worst case scenario is that the PLL has gone bad. In which case the radio will need to be fully aligned after replacing.
