Question about Canon Cameras
I'm trying to import video to my Mac but it won't recognize camera. Using Canon Optura 40, firewire, Mac OS 10.14.4, Final Cut Pro X and Adobe Premiere Pro 2019. Optura is set to VCR mode and play.
I believe potential problems could be output mode on camera, new software not compatible, bad cable. Can you help?
    New Friend:
  • 18 Answers
Use a card reader to retrieve the video
The camera uses a standard SD card
Posted on Sep 28, 2019
4 Suggested Answers
SOURCE:
  • 78 Answers
SOURCE: Importing Video to a Mac
XL2s are notorious for issues in interacting with final cut.
Simply put, sometimes it will work, sometimes it won't. But - there's a way around it.
Change the capture settings preset to 'non-controllable device'. Use the shuttle controls on top the handle of the XL2 to play back the footage as you wish. when you want to capture, click 'Capture Now' - It should do the trick.
Posted on Apr 08, 2008
SOURCE: No DV output from Canon GL2. Using a firewire
Was the tape your trying to import recorded on the camera you are trying to import from? I've noticed that sometimes the tape I recorded on my old Panasonic won't show up on my GL2. It's like it's a blank tape, but I know it's not, as I have it labeled. Stick it back into the panasonic and it plays fine.
Posted on Dec 20, 2009
SOURCE: Importing video from Xl1 canon into my Mac
I recently bout a canon xl1 but is curious to how i import footage from it into my new Imac? I have final cut express4 for my editing...CAN ANYBODY HELP ME WITH THIS? WHAT firewire cable do i need?
Posted on May 26, 2010
Hello, I want to download video clips from my Optura 50 tape onto my mac computer, and I have various adobe software applications available like final cut pro
You will require a firewire cable to connect to the Mac. Usually a 4 to 6 pin cable, the newer Macs use a 9 pin version.
iMovie will do the job as will Final Cut.
Mar 24, 2011 | Canon Optura 50 Mini DV Digital Camcorder
Tip
EOS Converter-Transcode Canon DSLR 550D Video to ProRes 422 in Full HD 1080p for...
Convert/Import Canon Rebel T2i/550D 1080/30fps H.264 MOV to ProRes 422 Codec for FCP 6/7 <br /><br />Canon EOS Digital Rebel T2i / 550D recorded videos are saved in H.264 for image and linear PCM for audio. You can choose different recording modes like full HD 1920&times;1080p at 30/25/24 fps, HD/SD 1280&times;720p/640&times;480 at 60/50 fps. Even though the videos are saved in .mov format, you may also face problem importing the video to Final Cut Pro. So you need a Mac Canon EOS Video Converter for converting and importing 550D1080p MOV for Final Cut Pro without rendering. Aunsoft Video Converter for Mac is the recommended <b><a href="http://www.aunsoft.com/video-converter-mac/">Mac Canon EOS Converter</a></b> for you to edit Digital Rebel T2i / 550D videos. <br /><br />Below is the quick guide for those who have a hard time editing Canon EOS Digital Rebel T2i / 550D H.264 MOV files to ProRes 422 at 30fps in Final Cut Pro 6 or 7. <br /><br />Step 1. Download Canon 550D MOV files to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b><a href="http://canon-videoconverter.com/2011/06/convertimport-canon-rebel-t2i550d-108030fps-mov-to-fcp-with-prores-codec/">Canon EOS Rebel T2i H.264 MOV to ProRes MOV converter</a></b> on Mac OS X. Click the "Add" button to import .mov files from the camera. <br /><br />Step 2. Choose MOV format with ProRes 422. <br />Click the "Format" option, and navigate to Final Cut Pro &gt; Apple ProRes 422 (*.mov) as output format. The Mac Digital SLR camera video converter will convert H.264 mov to prores 422 mov. <br /><br />You may notice that there are also other options like Apple ProRes 4444, Apple ProRes 422 (HQ), Apple ProRes 422 (LT), Apple ProRes 422 (Proxy), DVCPRO HD 1920*1080 30fps etc. <br /><br />Step 3. Choose 1080p size with 30fps. <br />Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution and 16:9 aspect ratio. Click the drop-down box for frame rate, and you can choose 30fps. <br /><br />Step 4. <b>Convert DSLR video to ProRes 422 HQ MOV for FCP.</b> <br />Click the convert button under the preview window, the <b>Mac Canon 550D DSLR video converter</b> will start <b><a href="http://prores-converter.com/2011/06/eos-converter-transcode-canon-dslr-550d-video-to-prores-422-in-full-hd-1080p-for-fcp-editing/">converting DSLR video to ProRes 422 in full HD 1080p for FCP editing</a></b>. <br /><br />After the conversion, you can import ProRes mov to Final Cut Pro without rendering.Hope you enjoy the optimal way to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Canon H.264 mov to ProRes 422 for FCP 7 and 6</a></b>, so that you can edit the H.264 files easily.
on Jun 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Mac Canon DSLR Video Converter-Transcode Canon EOS 5D H.264 MOV to iMovie on Mac
Converting Canon 5D Mark II Videos to iMovie 8/9 on Mac with Best Quality <br /><br /><b>Mac DSLR Video Converter</b> functions as the <b>Mac Canon DSLR video converter</b>, Mac Sony DSLR video converter, Mac Panasonic DSLR video converter, Mac Nikon DSLR video converter, Mac Kodak video converter, Mac Flip video converter and even Mac iPhone 4 video converter for your Apple computer with PowerPC or Intel CPU. <br /><br /><b>Mac DSLR Video Converter</b> enables you to <b>import H.264 MOV videos from Digital SLR cameras</b> to editing software like iMovie 8/9/11,Final Cut Express,Final Cut Pro,Final Cut Studio,Adobe Premiere Pro,Avid etc. <br /><br /><b>Mac DSLR Video Converter</b> helps you organize DSLR recordings from camcorders like Sony VG10, Canon 600D in AVCHD MTS/M2TS, MOV formats, and <b>convert MTS/M2TS and H.264 MOV to Mac</b> editable format. <br /><br />Below is the quick guide for you to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Canon 5D Mark II videos to iMovie</a></b> with Aunsoft Video Converter for Mac OS X like Snow Leopard, Leopard and Tiger. <br /><br />Step 1. Import Canon DSLR MOV to Aunsoft Video Converter for Mac. <br />After the movie clips are transferred to Apple computer hard drive, run Aunsoft Video Converter for Mac as the best <b><a href="http://canon-videoconverter.com/2011/06/mac-canon-dslr-video-converter-transcodingconverting-canon-eos-5d-mark-ii-h-264-mov-to-imovie-on-mac/">Mac Canon DSLR Video converter</a></b>. Click the "Add" button to browse the Canon DSLR .mov files for conversion. <br /><br />Step 2. Choose QuickTime MOV format. <br />Click the "Format" option and navigate the mouse cursor to Common Video &gt; MOV - QuickTime(*.mov) as output format. The Mac DSLR movie converter will <b><a href="http://www.aunsoft.com/video-converter-mac/">transcode Canon H.264 videos to iMovie</a></b> supported videos with original resolution in 1920x1080. <br /><br />To change video frame rate, just click the "Settings" button and choose the frame rate option. <br /><br />Step 3. Convert Canon DSLR EOS MOV for iMovie. <br />Click the convert button under the preview window, and the Mac Canon DSLR movie converter will start <b><a href="http://www.aunsoft.com/video-converter-mac/">converting Canon H.264 MOV to QuickTime MOV</a></b> for editing in iMovie with high quality. <br /><br />After the conversion, just import the output videos to iMovie 8, iMovie 9 or even iMovie 11 for creating your own movies.
on Jun 08, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
No DV output from Canon GL2. Using a firewire cable from DV port on camera to firewire port on Mac Pro tower. Attempting to import the camera live to Final Cut Pro. Previously worked just fine.
Nov 12, 2009 | Canon GL2 Mini DV Digital Camcorder
Apr 08, 2008 | Canon XL2 Mini DV Digital Camcorder
JVC Everio HD3 - video format problem for MAC
Have a look at http://software.transdigital.co.jp/products/cbs_ev/qc_eng/index.htm
There are instructions and links to solve the problem
Mar 28, 2008 | Cameras
you must use the third party software convert your video files format to final cut express support formats.such as dv,mp4,mov
if your video files is .tod format,you can use tod to final cut express converter.
http://www.fceconverter.com/tod-to-final-cut-express/
if it's .mod files format, you can use mod to final cut express converter
http://www.fceconverter.com/mod-to-final-cut-express/
Mar 27, 2008 | Sony Handycam DCR-TRV18 Mini DV Digital...
Software for Mac application lost
Your Mac video program should have or be able to download the appropriate driver for your camcorder when you want to capture the video from it. I have been using Final Cut Pro with no problems with the Canon Optura XI.
Dec 18, 2007 | Canon Optura Xi Mini DV Digital Camcorder
Cameras Logo
48 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
