SOURCE: Beeps coming from over by the glove box after turning engine off.
the beeps are an airbag trouble code, that code is for the following:
In most cases this problem is caused by the rotating ribbon circuit contact under the steering wheel having a broken filament, the part is known as a clock spring contact, u will need to properly disarm the airbag and remove the steering wheel to access the part. WARNING: Failure to follow factory Airbag disarming protocol can result in an unexpected Airbag deployment and possible serious personnel injury or death.
SOURCE: 9 beeps gogo elite traveler
hi, 9 bleeps on a go go mean a parking brake fault or motor connection problem , now it could just a be case of a poor connecting however go you confirm the exact controller used ?
Check the brake connections and motor cable connections making sure they are clean and tight.
Regards
