SOURCE: sharp ar 5520 fault code
F2 40 = ATC sensor abnormality
Check e remedy :
Remove/Install the toner cartridge again.
Replace the toner cartridge with a normal one.
SOURCE: Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
This error is self resetting so no need of simulation code. Bye.
SOURCE: HOW CAN I OPERATE SHARP AR 5520 COPIER WITH 30 KVA GENERATO POWER SUPPLY?
Hi, this power is not stable and enough. You need a big generator to work with this machine since it needs more power and you will agree with me that once you connected, the sound of the generator changed.
Dear
The ink cart. is dual component one is drum unit and other is toner unit. You may go to system information there consumable information which indicate the status of the both and according to that replace the chip of the respective cart.
Thanks.
SOURCE: comment proceder a l etallonnage du developpeur du photocopieur AR 5520
how to calibrate the developer of the AR 5520 photocopier
https://translate.google.com/#view=home&op=translate&sl=auto&tl=en&text=comment%20proceder%20a%20l%20etallonnage%20du%20developpeur%20du%20photocopieur%20AR%205520
https://www.sharp.eu/cps/rde/xbcr/documents/documents/om/34_ppc/ar5516-d-5520-d_om_gb.pdf
Google Translate peut traduire une page individuelle d'un fichier PDF ou de petits fichiers PDF de l'anglais vers le fran?ais. Les gros fichiers ne peuvent pas ?tre traduits. J'essaie de t?l?charger une version du manuel PDF s?par?e en 90 pages afin que vous puissiez choisir de traduire des pages ? l'aide de Google translate.
Google translate can translate individual page of a PDF file, or small PDF files from English to French. Large files cannot be translated. I am trying to upload a version of the PDF manual separated into 90 pages so you can choose to translate pages using Google translate.
