SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
SOURCE: Machine stops after 2-3 stitches
open your bobbin case and un jam it thread wound around the center
SOURCE: Hi I have a cee100
i spoke with support and they tell me that this is a threading issue. pull the thread back and forth, like flossing, under the plastic plate on top so the thread clicks into place. then procede with threading.
SOURCE: I have a Kenmore sewing
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
SOURCE: foot pedal not working
yes, it is possible that the foot pedal can go out,, it would be a good
idea to have the foot pedal checked at a repair shop to see for
sure
Testimonial: "I went to sewing machine store today and the pedal checked out as dying, so ordered a new one. Thx again!"
The foot controller was pressed (or the start/stop button
was pressed if the foot controller is not connected)
and the reverse/reinforcement stitch button
was pressed while the presser foot was raised.
